Toolchains Builder
- Category: CodeTyphon CTCenter
- Published: Friday, 24 February 2017 09:02
- Hits: 23433
Toolchain Builder is the font-end form, of CodeTyphon Toolchains Engine
You can build any CPU-OS Toolchain supported by GNU binutils.
Toolchains Engine will build the Toolchain with your parameters
and will put all files to Toolchains Library, ready to use from Typhon IDE.
1) Select Target CPU and Target OS
2) Select Host
3) Hit "build" to start building procedure...
Select CPU-OS or CPU or OS
Select Host
Hit build to start building
"FPC CPU-OS targets" list show only the targets that FreePascal compiler can support.
But, with this tools you can build more...
