pl_ZenGL
- Category: Graphics
- Published: Sunday, 20 October 2013 06:05
- Hits: 21938
pl_ZenGL
It's a fork of ZenGL library to CodeTyphon Studio.
ZenGL is cross-platform game development library written in Pascal.
Designed to provide necessary functionality for rendering 2D-graphics, handling input, sound output, etc
Features
- Main
- can be used as so/dll/dylib or statically compiled with your application
- rendering to own or any other prepared window
- logging
- resource loading from files, memory and zip archives
- multithreaded resource loading
- easy way to add support for new resource format
- Configuration of
- antialiasing, screen resolution, refresh rate and vertical synchronization
- aspect correction
- title, position and size of window
- cursor visibility in window space
- Input
- handling keyboard, mouse and joystick input
- handling of Unicode text input
- possibility to restrict the input to the Latin alphabet
- Textures
- supports tga, png, jpg and pvr
- correct work with NPOT textures
- control the filter parameters
- masking
- render targets for rendering into texture
- Text
- textured Unicode-font
- rendering UTF-8 text
- rendering text with alignment and other options like size, color and count of symbols
- 2D-subsystem
- batch render for high-speed rendering
- rendering different primitives
- sprite engine
- rendering static and animated sprites and tiles
- rendering distortion grid
- rendering sprites with new texture coordinates(with the pixel dimension and the usual 0..1)
- control the blend mode and color mix mode
- control the color and alpha of vertices of sprites and primitives
- additional sprite transformations(flipping, zooming, vertices offset)
- fast clipping of invisible sprites
- 2D camera with ability to zoom and rotate the scene
- Sound
- works through OpenAL or DirectSound, depends on configuration or OS
- correct work without soundcard
- supports wav and ogg as sound samples
- playing audio files in separate thread
- control the volume and playback speed
- moving sound sources in 3D space
- Video
- decoding video frames into texture
- supports theora codec in ogv container
- Mathematic
- basic set of additional math functions
- triangulation functions
- basic set of collision functions
- Additional
- reading and writing ini-files
- functions for work with files and memory
Home page: http://zengl.org
Source Documentation
