Pascal - Pointers
- Category: Chapter 3
- Published: Sunday, 14 April 2013 16:40
- Hits: 21935
Pointers in Pascal are easy and fun to learn. Some Pascal programming tasks are performed more easily with pointers, and other tasks, such as dynamic memory allocation, cannot be performed without using pointers. So it becomes necessary to learn pointers to become a perfect Pascal programmer. Let's start learning them in simple and easy steps.
As you know every variable is a memory location and every memory location has its address defined which can be accessed using the name of the pointer variable, which denotes an address in memory.
1. What Are Pointers?
A pointer is a dynamic variable whose value is the address of another variable i.e. direct address of the memory location. Like any variable or constant, you must declare a pointer before you can use it to store any variable address. The general form of a pointer variable declaration is:
type ptr-identifier =^base-variable-type;
The pointer type is defined by prefixing the up-arrow of caret symbol (^) with the base type. The base-type defines the types of the data items. Once a pointer variable is defined to be of certain type, it can point data items of that type only. Once a pointer type has been defined, we can use the var declaration to declare pointer variables.
var p1, p2,...: ptr-identifier;
Following are some valid pointer declarations:
type Rptr=^real; Cptr=^char; Bptr=^Boolean; Aptr=^array[1..5] of real; date-ptr =^ date; Date= record Day:1..31; Month:1..12; Year:1900..3000; End;var a, b :Rptr; d: date-ptr;
The pointer variables are dereferenced by using the same caret symbol(^). For example, the associated variable referred by a pointer rptr, is rptr^. It can be accessed as:
rptr^:=234.56;
The following example will illustrate this concept:
program exPointers; var number: integer; iptr:^integer; begin number :=100; writeln('Number is: ', number); iptr :=@number; writeln('iptr points to a value: ', iptr^); iptr^:=200; writeln('Number is: ', number); writeln('iptr points to a value: ', iptr^); end.
Number is: 100 iptr points to a value: 100 Number is: 200 iptr points to a value: 200
2. Printing a Memory Address in Pascal
In Pascal, we can assign the address of a variable to a pointer variable using the address operator (@). We use this pointer to manipulate and access the data item. However, if for some reason, we need to work with the memory address itself, we need to store it in a word type variable.
Let us extend the above example to print the memory address stored in the pointer iptr:
program exPointers; var number: integer; iptr:^integer; y:^word; begin number :=100; writeln('Number is: ', number); iptr :=@number; writeln('iptr points to a value: ', iptr^); iptr^:=200; writeln('Number is: ', number); writeln('iptr points to a value: ', iptr^); y := addr(iptr); writeln(y^); end.
Number is: 100 iptr points to a value: 100 Number is: 200 iptr points to a value: 200 36864
3. NILL Pointers
It is always a good practice to assign a NILL value to a pointer variable in case you do not have exact address to be assigned. This is done at the time of variable declaration. A pointer that is assigned NILL points to nowhere. Consider the following program:
program exPointers; var number: integer; iptr:^integer; y:^word; begin iptr :=nil; y := addr(iptr); writeln('the vaule of iptr is ', y^); end.
The value of ptr is 0
To check for a nil pointer you can use an if statement as follows:
if NOT (ptr=nil) then //succeeds if p is not null if(ptr=nil) then //succeeds if p is null
4. Pascal Pointers in Detail:
Pointers have many but easy concepts and they are very important to Pascal programming. There are following few important pointer concepts which should be clear to a Pascal programmer:
| Concept | Description |
| Pascal - Pointer arithmetic | There are four arithmetic operators that can be used on pointers: increment,decrement, +, - |
| Pascal - Array of pointers | You can define arrays to hold a number of pointers. |
| Pascal - Pointer to pointer | Pascal allows you to have pointer on a pointer and so on. |
| Passing pointers to subprograms in Pascal | Passing an argument by reference or by address both enable the passed argument to be changed in the calling subprogram by the called subprogram. |
| Return pointer from subprograms in Pascal | Pascal allows a subprogram to return a pointer. |
