Pascal - Array of Pointers
- Category: Chapter 3
- Published: Sunday, 14 April 2013 17:08
- Hits: 19804
Pascal allows defining an array of pointers. There may be a situation when we want to maintain an array which can store pointers to integers or characters or any other data type available. Following is the declaration of an array of pointers to an integer:
type iptr =^integer; var parray: array [1..MAX] of iptr;
This declares parray as an array of MAX integer pointers. Thus, each element in parray, now holds a pointer to an integer value. Following example makes use of three integers which will be stored in an array of pointers as follows:
program exPointers; const MAX =3; type iptr =^integer; var arr: array [1..MAX] of integer =(10,100,200); i: integer; parray: array[1..MAX] of iptr; begin (* let us assign the addresses to parray *) for i:=1 to MAX do parray[i]:=@arr[i]; (* let us print the values using the pointer array *) for i:=1 to MAX do writeln(' Value of arr[', i,'] = ', parray[i]^); end.
You can also use an array of pointers to string variables to store a list of strings as follows:
program exPointers; const MAX =4; type sptr =^string; var i: integer; names: array [1..4] of string=('Zara Ali','Hina Ali', 'Nuha Ali','Sara Ali'); parray: array[1..MAX] of sptr; begin for i :=1 to MAX do parray[i]:=@names[i]; for i:=1 to MAX do writeln('Value of names[', i,'] = ', parray[i]^); end.
Value of names[1] = Zara Ali Value of names[2] = Hina Ali Value of names[3] = Nuha Ali Value of names[4] = Sara Ali
