pl_OpenGLPT
- Category: Graphics 3D
- Published: Wednesday, 29 December 2021 06:31
- Written by Administrator
- Hits: 6321
pl_OpenGLPT
it's a fork of OpenGL Pascal Toolkit Library to CodeTyphon Studio.
An easy to use native pascal toolkit that allows to create and manage OpenGL contexts in a platform independent way
Using GLPT is easy, you only need to include the GLPT unit and create a window.
Then run the event loop and do all your application stuff there.
There are numerous examples included to help you to make a jump start.
GLPT is planned to be a simple and easy to use library. When working on the code please consider the following:
- flat API, so no classes and no objects.
- no external dependencies are allowed, also adding FPC units should be considered carefully.
- only OpenGL context handling, no audio, font or UI included to name a few.
Home page: https://github.com/daar/GLPT
Source Documentation
