Pascal - Break Statement
- Category: Chapter 2
- Published: Sunday, 14 April 2013 14:44
- Hits: 23555
The break statement in Pascal has the following two usages:
When the break statement is encountered inside a loop, the loop is immediately terminated and program control resumes at the next statement following the loop.
- It can be used to terminate a case in the case statement (covered in the next chapter).
- If you are using nested loops ( ie. one loop inside another loop), the break statement will stop the execution of the innermost loop and start executing the next line of code after the block.
1. Syntax:
The syntax for a break statement in Pascal is as follows:
break;
2. Flow Diagram:
3. Example:
program exBreak; var a: integer; begin a :=10; while (a<20) do begin writeln('value of a: ', a); a:=a +1; if (a>15) then break; {terminate the loop} end; end.
value of a: 10 value of a: 11 value of a: 12 value of a: 13 value of a: 14 value of a: 15
