Installation on NetBSD
- Published: Saturday, 24 August 2019 20:20
- Written by Administrator
- Hits: 12148
WARNING : On NetBSD OS, this installation request a user with sudo root privileges.
1. Step : Preparation
1.1. Give to installation user sudo root privileges.
Open the file “sudoers” located at /usr/pkg/etc/sudoers using your favorite text editor.
If you use nano editor you can simply enter the following into the Terminal:
su
nano /usr/pkg/etc/sudoers
user ALL=(ALL) NOPASSWD: ALL
1.2. Give to installation user access to OS libraries
This procedure NOT needed to build FPC and Typhon IDE,
needed to run any GUI application on NetBSD.
Globally to ALL OS users
su
nano /etc/profile
add as last line:
export LD_LIBRARY_PATH=/usr/pkg/lib:/usr/X11R7/lib
OR
Locally only to current user
nano ~/.profile
add as last line:
2. Step : Download
Download CodeTyphonIns.zip to your /home directory
3. Step : Install
Go to CodeTyphonIns directory and execute the "install.sh" (as "normal" user with "sudo" root privileges)
To execute from terminal install.sh script
sh ./install.sh (execute install.sh)
4. Step : Setup and Build
After install script CT automatic will start Setup script .
NOTE:
From "Setup Script" Select option (0) "Install System Libraries", to install some System Libraries
(2-5 minutes procedure)
From "Setup Script" select option (8) "Remove and Build ALL" to Build Freepascal and Typhon IDE from source.
(10-45 minutes procedure)
5. Step : Use CT
