Installation on MacOS
- Published: Monday, 08 December 2014 02:15
- Written by Administrator
- Hits: 37609
WARNING: On MacOS X OS, this installation request a user with sudo root privileges.
1. Step : Preparation
a) Install Xcode from Apple Store
b) Accept Xcode license
Open a terminal and execute:
sudo xcodebuild -license
c) Install command line developer tools
xcode-select --install
d) Install MacPorts https://www.macports.org
e) Turn off Gatekeeper, to Allow apps downloaded from Anywhere.
sudo spctl --master-disable
f) Give to installation user sudo root privileges.
How to add a user to the sudoers list:
Open the file “sudoers” located at /etc/sudoers using your favorite text editor.
If you use nano editor you can simply enter the following into the Terminal:
sudo nano /etc/sudoers
user ALL=(ALL) NOPASSWD: ALL
2. Step : Download
Download CodeTyphonIns.zip
to your /home directory
3. Step : Install
Go to CodeTyphonIns directory and execute the "install.sh" (as "normal" user with "sudo" root privileges)
To execute from terminal install.sh script
sh ./install.sh (execute install.sh)
4. Step : Setup and Build
From "Setup Script" Select option (0) "Install System Libraries", to install some System Libraries.
(2-5 minutes procedure)
From "Setup Script"
(10-20 minutes procedure)
5. Step : Use CT
