Setup Script Options
- Published: Tuesday, 30 April 2013 17:48
- Hits: 27804
The "Setup Script" is an operating system batch file.
Can execute only 8 actions.
If you want more actions, after CodeTyphon Install, close this script and open CTCenter
1. On Windows
c:\codetyphon\setup.bat
2. On Unix OSes
For Linux, FreeBSD, NetBSD, OpenBSD, NetBSD, Solaris, OpenIndiana and MacOS
/usr/local/codetyphon/setup.sh
3. Options
0) Install System Libraries.
This action will install all libraries "must have" to your Programming PC for Selected Platform.
1) Run CodeTyphon Center.
This action start CodeTyphon Center.
11) CodeTyphon Platform (widget) Setup. (GTK2, QT4, QT5, Cocoa etc).
12) CodeTyphon Multi-Architecture Setup.
3) Remove FreePascal.
This action removes FreePascal directories from CodeTyphon Studio.
4) Remove and Build FreePascal.
This action removes FreePascal directories from CodeTyphon Studio and then will build FreePascal compiler from sources.
5) Remove Typhon IDE.
This action removes Typhon IDE directories from CodeTyphon Studio.
6) Remove and Build Typhon IDE.
This action first removes Typhon IDE and CodeOCean directories from CodeTyphon Studio and then will build Typhon IDE from sources.
If FreePascal NOT exists to your CodeTyphon Folder, this action will build and FreePascal compiler from sources
7) Remove ALL.
This action removes Typhon IDE and FreePascal from CodeTyphon Studio directory.
WARNING: This procedure removes and Typhon IDE temporary project files directory, so backup your projects first.
8) Remove and Build ALL.
This action first removes Typhon IDE, CodeOcean and FreePascal from CodeTyphon Studio directory and then will
build Typhon IDE and FreePascal from code sources.
9) Exit.
This action terminates Setup Script.
Note: For Unix OSes, setup script gives to all CodeTyphon files and directories the correct permissions.
For CodeTyphon directories please read here
