CT LAB ver 8.10 3 years 5 months ago #17769
  • HIGH-Zen
  • HIGH-Zen's Avatar
CT LAB ver 8.10 3 years 4 months ago #17771
  • HIGH-Zen
  • HIGH-Zen's Avatar
Hint: I did try setup TSqlite3Dataset in design time. If I click Activate in design time I got Access violation.
CT LAB ver 8.10 3 years 4 months ago #17773
  • HIGH-Zen
  • HIGH-Zen's Avatar
Small bug:
I find out that keyboard shortcut Ctrl+F11 doesn't work. Menu item Project -> Open Project...
(CodeTyphon 8.10 rev. 008070 (Win 11 Pro, 16GB RAM) Win64 BigIDE)
Last edit: by HIGH-Zen. Reason: more info added
CT LAB ver 8.10 3 years 4 months ago #17774
  • Thank you received: 230
Hello!
I built CodeTyphon 8.10 rev. 008070 (Win 11 Pro, 16GB RAM) Win64 BigIDE.
And tested for TSqlite3Dataset BUG.
TSqlite3Dataset BUG
I can confirm that BUG exists. I get Access violation.
I tested example project with ancient version CT 6.70 Win64 BigIDE too, with same results. So this is very old bug.
Can somebody help?
We fixed this
-Replace C:\codetyphon\fpcsrc\packages\fcl-db\src\sqlite\sqlite3ds.pas
with attach file
-Build FPC
-Rebuild TyphonIDE if you want to  test the new TSqlite3Dataset property ClientLibrary
The following user(s) said Thank You: HIGH-Zen
CT LAB ver 8.10 3 years 4 months ago #17775
  • HIGH-Zen
  • HIGH-Zen's Avatar
Thank You!
Now everything works fine.
After rebuild keyboard shortcut Ctrl+F11 works too.
CT LAB ver 8.10 3 years 4 months ago #17777
The final Fix
CT LAB ver 8.10 3 years 4 months ago #17778
  • HIGH-Zen
  • HIGH-Zen's Avatar
Tested. It works!
CT LAB ver 8.10 3 years 4 months ago #17781
  • HIGH-Zen
  • HIGH-Zen's Avatar
Not a big deal but I found an IDE bug.
Steps to reproduce:
1. Open Typhon64 IDE.
2. Settings -> Options... -> IDE Options -> General Extra -> Uncheck "Use Docking System", uncheck "Use Embedded Form Designer"
Press OK.
3. Close Typhon64 IDE.
4. Open Typhon64 IDE.
5. Open menu - Tools -> CodeOcean Examples. CodeOcean Examples window opens.
6. Then close IDE.
7. Open Typhon64 IDE again.
8. Close CodeOcean Examples window.
9. Close IDE.
And then error "Access violation." happens.
Clean build: CodeTyphon 8.10 rev. 008070 (Win 11 Pro, 16GB RAM) Win64 BigIDE.
CT LAB ver 8.10 3 years 4 months ago #17782
we will try to fix this
CT LAB ver 8.10 3 years 4 months ago #17784
  • HIGH-Zen
  • HIGH-Zen's Avatar
Small bug:
I found why Ctrl+F11 sometimes does not work.
It is because  GoldenDict steals shortcut Ctrl+F11. Close GoldenDict and you would get keyboard shortcut back. :)
CT LAB ver 8.10 3 years 4 months ago #17785
Here Ctrl+F11 works OK
CT LAB ver 8.10 3 years 4 months ago #17788
We start "Windows Dark Theme" LAB tests,
for TyphonIDE and user Applications
Screen from Windows 11 22H2 IDE Tests
The following user(s) said Thank You: Konstantinos Papadoulas, Toky Olivier Razanakotonarivo
CT LAB ver 8.10 3 years 4 months ago #17790
  • sleepybird
  • sleepybird's Avatar
Sir,
Does dark theme is applicable on string grid and db grid.
CT LAB ver 8.10 3 years 4 months ago #17791
Yes Sir
Screen from Windows 10 22H2
CT LAB ver 8.10 3 years 4 months ago #17792
  • HIGH-Zen
  • HIGH-Zen's Avatar
I tested CodeTyphon 8.00 on linuxmint-21.1-mate-64bit.iso and can't install Typhon IDE. Tested on linuxmint-19.3-mate-64bit.iso and it worked fine. Maybe you can test it too.
CT LAB ver 8.10 3 years 4 months ago #17793
Thanks,
we will test and report here
CT LAB ver 8.10 3 years 4 months ago #17794
  • HIGH-Zen
  • HIGH-Zen's Avatar
I think linuxmint-21.1-mate-64bit.iso is buggy distribution. My own programs do not work as expected. I tested my programs on ubuntu and debian and have no problems. So I think it is not CodeTyphon fault.
CT LAB ver 8.10 3 years 4 months ago #17795
Please, give us time
we build Final CT ver 8.10 now.
We will test and  linuxmint-21.1-mate-64bit.iso
CT LAB ver 8.10 3 years 4 months ago #17796
CodeTyphon Final ver 8.10 on
LinuxMint 21.1 (linuxmint-21.1-mate-64bit.iso)
MultiArch , MultiPlatform for GTK2, QT5 and QT6.
The following user(s) said Thank You: Konstantinos Papadoulas, Jan Roza, HIGH-Zen
CT LAB ver 8.10 3 years 4 months ago #17797
  • HIGH-Zen
  • HIGH-Zen's Avatar
Cool! Thank you! :)
