Package with Pas2JS 4 years 5 months ago #17069
  • Toky Olivier Razanakotonarivo
  • Toky Olivier Razanakotonarivo's Avatar Topic Author
Can you tell please how to create new Package for Pas2JS (based on JsWebWidget components?).
Every time I create one, I cannot compile it.
I will create a Package with a new widgetset based on Boostrap and post it here when finished.
I use CT 7.7 on Windows 10.
Best regards,
Toky
Last edit: by Toky Olivier Razanakotonarivo.
Package with Pas2JS 4 years 5 months ago #17070
Sorry, I put this question in a wrong Category, is it possible to move it to CT Web development Category please?
Thank you.
Package with Pas2JS 4 years 5 months ago #17073
  • Thank you received: 236
You must save your new Pas2JS pkg to a folder that is visible to Pas2JS Compiler.
By default only
codetyphon/typhon/components/packages_js/*
folders are visible to Pas2JS
You can see this at Pas2JS Compiler config file:
codetyphon\fpc\fpc64\bin\x86_64-win64\pas2js.cnf
​​​​​​​-FuC:\codetyphon/fpcsrc/utils/pas2js/dist
-FuC:\codetyphon/typhon/components/packages_js/*
So you can:
a) save your new Pas2JS pkg in
folder for sample:
codetyphon/typhon/components/packages_js/js_mynewpkg
OR
b) save your new Pas2JS pkg in any folder you want, but
add the path to Pas2JS Compiler config file pas2js.cnf.
