in fpWeb, Actions does not work properly 10 years 8 months ago #9219
  • Edgar Rodríguez
  • Edgar Rodríguez's Avatar Topic Author
Hi, I was trying to change content property in some actions in the module, I save, compile and check the cgi in the browser, no change... try again and again... no results, I changed other property like Name of the Action, and no flag either, changed the tag and saved, and it worked, what is is going on? simple... after modifying the Actions property, it does not activate the "modified" flag to let the IDE save... it's a minor bug, I think...
Last edit: by Edgar Rodríguez.
in fpWeb, Actions does not work properly 10 years 8 months ago #9221
we will check this
The following user(s) said Thank You: Edgar Rodríguez
