RAUDUS 11 years 6 months ago #7298
  • LUIZ SANTOS
  • LUIZ SANTOS's Avatar Topic Author
Hello!
Does someone know how to install RAUDUS 0.99 in last Typhon version?
Thanks.
Luiz
RAUDUS 11 years 6 months ago #7305
  • Tony_O_Gallos
  • Tony_O_Gallos's Avatar
  • Thank you received: 24
Hi lposantos,
I think it will not be possible :(
Raudus is free to use, but not open-source.
Its installation process is totaly version dependant, based for 0.9.9b on Lazarus 1.26 32bit and FPC 2.64.
It uses the "welding.exe" in order to patch Lazarus' original ppu, because it is only distributed as binairies.
CodeTyphon is a (partially) modified version of Lazarus, but using a more recent version of source code and of course a more recent FPC version.
Binaries will not be compatible, even if you "cheat" by installing binaries by hand if will fail during recompilation of the IDE.
The only possibility for you is to use an official verison of Lazarus (1.2.6 32bit, not even a 1.4.0) :/
Another proof open-source is always better!
Last edit: by Tony_O_Gallos.
