CodeTyphon 4.00 GEN IV 13 years 9 months ago #3189
  • Arioch
  • Arioch's Avatar
We are happy too!
Well, it perhaps would be a lost weekend now, but thatnk you for great package!
I truly hope 1st digit flip was worth it!
Thanks!
CodeTyphon 4.00 GEN IV 13 years 9 months ago #3190
CodeTyphon 4.00 GEN IV 13 years 9 months ago #3192
  • opc0de
  • opc0de's Avatar
Congratulations! CT rocks!
CodeTyphon 4.00 GEN IV 13 years 9 months ago #3198
  • azrael11
  • azrael11's Avatar
Γείας σας παιδιά ...
Τα καινούρια χαρακτηριστικά που διάβασα στο change long είναι εντυπωσιακά...
Μπράβο για την καταπληκτική δουλειά σας...
Πήγα να κατεβάσω την τελευταία έκδοση και στο downloads page έχει ακόμη την 3.10...
Ευχαριστώ πολύ...
Free minds... with focus in future...
CodeTyphon 4.00 GEN IV 13 years 9 months ago #3199
You can download now, CT ver 4.00
from our Server link
CodeTyphon 4.00 GEN IV 13 years 9 months ago #3201
  • azrael11
  • azrael11's Avatar
Thank you very much...
CodeTyphon 4.00 GEN IV 13 years 9 months ago #3202
Please Sir
don't forget your first report :)
CodeTyphon 4.00 GEN IV 13 years 9 months ago #3203
  • azrael11
  • azrael11's Avatar
sternas wrote: Please Sir
All OK...
Install
1> WindowsXP SP3 32Bit Build OK
2> Linux MINT latest 32Bit Build OK
Perfect...
Ολα καλά πήγανε και νομίζω η εγκατάσταση έγινε πιο γρήγορα από την προηγούμενη φορά....
Περιμένω με αγωνία την έκδοση για MACOSX..
Thank you...
CodeTyphon 4.00 GEN IV 13 years 9 months ago #3204
  • Helder R. C.
  • Helder R. C.'s Avatar
Thank you PilotLogic! :laugh:
Mr. Sternas, what about 7zip compression to reduce download file? I did read about this here... this is a discarded idea?
CodeTyphon 4.00 GEN IV 13 years 8 months ago #3205
  • ExDatis
  • ExDatis's Avatar
Excellent work(CT4)! Thank you!
CodeTyphon 4.00 GEN IV 13 years 8 months ago #3206
hrayon wrote: Thank you PilotLogic! :laugh:
No Sir
the only zip compression file is the install file CodeTyphonIns.zip,
for OS compatibility reason
Ver 4.0 has for all files 7zip compression
but has and a lot of new things (like GCC 32/64 bin and sources)
With zip compression CT ver 4.0 has 1.2 Gbytes install file (CodeTyphonIns.zip)
but don't worry CT has now "rolling installation".
CodeTyphon 4.00 GEN IV 13 years 8 months ago #3207
  • azrael11
  • azrael11's Avatar
Try to open the "multilang" example from ORCA 2D and the lazarus is stuck...
This is the only example from ORCA that is stuck... any ideas...
Thank you...
CodeTyphon 4.00 GEN IV 13 years 8 months ago #3208
  • engerex engerex
  • engerex engerex's Avatar
Windows XP SP3 >>>
'\binCenter\i386-win32-win32\win32\' CodeTyphon.exe not found
existing file= C:\codetyphon\binCenter\i386-win32-win32\CodeTyphon.exe
CodeTyphon 4.00 GEN IV 13 years 8 months ago #3209
Please remove ALL links and files from old CT
and then install the new version 4.0
The new ver 4.0 CT has CTCenter for win32 to:
The following user(s) said Thank You: Arioch
CodeTyphon 4.00 GEN IV 13 years 8 months ago #3210
  • Arioch
  • Arioch's Avatar
About traffic and server load - dunno how much downloaders u have, but maybe it could worth to use P2P acceleration ? make your server just one of the file sources in G2 or BitTorrent cloud
About compression.
One one hand, thanks to p7zip.sf.net, 7-zip compression is x-platform today. OTOH i think that ZIP generally works good enough on text files. Yes, PPMD codec is still better, but zip is good enough. I think the problem is discrete files storage in ZIPs than makes zip codec discard its experience on every file boundary. 7-zip/RAR could win much due to solid archive mode.
But i also think if CT distribution be solidified by TAR - separating different kinds of files (binary for different platforms, pas/pp source, lfm sources) into separate TAR streams - and then compressing those homogenic TARs with BZ2 or that very ZIP (to keep it in one file for download), my blind guess is that results would be pretty close to ones of 7-zip
CodeTyphon 4.00 GEN IV 13 years 8 months ago #3211
  • Arioch
  • Arioch's Avatar
My c: is SSD hence it is relatively small and it is wearing out. I use default C:\CodeTyphon path for installation (to make compilation fast, including rebuilding of IDE) but i unpack distro into n:\CodeTyphonIns\
As i start it and selected update - updaters fails with some error like some binary compiler not found (i know it sounds silly, i should have recorded it, but...
Then on the second run it went okay until the menu if i want to start center or to rebuild FPC and/or LAzarus
After i selected "1" bat file quit with "1 is bad command or fie name" diagnostics.
Then it quit with
Не удается найти файл binCenter\x86_64-win64\win32\CodeTyphon.exe.
Correct path would be c:\codetyphon\binCenter\x86_64-win64-win32\CodeTyphon.exe
PS: why not making few changes to install.bat to be able to install form any folder to any other ?
Last edit: by Arioch.
CodeTyphon 4.00 GEN IV 13 years 8 months ago #3212
Arioch wrote: My c: is SSD hence it is relatively small and it is wearing out. I use default C:\CodeTyphon path for installation (to make compilation fast, including rebuilding of IDE) but i unpack distro into n:\CodeTyphonIns\
Then it quit with
Please Sir
remove CT old desk links manual
and reinstall CT ver 4.00
CodeTyphon 4.00 GEN IV 13 years 8 months ago #3213
  • Arioch
  • Arioch's Avatar
sternas wrote: remove CT old desk links manual
what ?
i run it from command prompt (from console). Desktop shortcuts do not have to deal with it.
And anyway, whatever i have on my desktop cannot matter after i started correct install.bat from unpacked distro
Also - please compare the paths - you made typo in win64 center path in your bat file
Now i made build Lazarus Win64 in the Center - there were few erros in the log, maybe i'd be able to find it. Would it be better reporting them here or in separate thread ?
CodeTyphon 4.00 GEN IV 13 years 8 months ago #3214
Arioch wrote: About traffic and server load - dunno how much downloaders u have, but maybe it could worth to use P2P acceleration ? make your server just one of the file sources in G2 or BitTorrent cloud
About compression.
we test all compression Application/methods
but 7zip has the best completion ration for
the final CT installation file (about 50% smaller total size from zip)
and it's real multi-OS without problems.
Some of compression Application/methods out there
are true "Software zombies"
The programmer's question is simple:
"Practical, can I use the same TAR or BZ2 (or any other type) compressed file
to All CT host Layers, windows, Linux, FreeBSD, Solaris etc ?"
Our lab test say: Only with zip and 7Zip
CodeTyphon 4.00 GEN IV 13 years 8 months ago #3215
  • engerex engerex
sternas wrote: Please remove ALL links and files from old CT
I found the problem.
Setup.bat > line 157
_____________________________________________________________
rem @@@@@@@@@@@@@@@@@@@@ Run CodeTyphon @@@@@@@@@@@@@@@@@@@@@
:GO_1
START binCenter\%varzipdir%\win32\CodeTyphon.exe
GOTO GO_END
