CT LAB ver 8.50 2 years 3 weeks ago #18644
I'm not sure if this is a bug or that it has been like this always.
In Settings - Window I have checked 'IDE title shows project directory' and in the undocked IDE the directory is shown in the IDE title, but after changing to an all docked IDE the project directory is not shown any more in the IDE title.
See attached screenshot.
CT LAB ver 8.50 2 years 3 weeks ago #18646
the LAB CT 8.60 (Unreleased) has and Custom Settings.
The default is TyphonXX+ ProjectName+ (ProjectDir)+etc...
We are working on that....
CT LAB ver 8.50 2 years 3 weeks ago #18647
Thanks Matis, this custom IDE title option works exactly how I wanted it.
When 8.6 comes out I'll see what other wonders you have performed.
Last edit: by Jan Roza.
CT LAB ver 8.50 1 year 11 months ago #18698
  • tmallet.tm
  • tmallet.tm's Avatar
Hello Sir,
I am trying to make my application work with Orca (It works fine with GTK2).
The ShowModal call seems not to work properly, and the form never closes, even with the window close button.
So I open the CodeOcean sample (pl_Orca/samples/ctrlsdemo) to see what I am doing wrong and the result is the same: impossible to close the "About..." form.
Only solution: kill the application.
PS: Moving the form with the mouse seems not to work properly either (The window jumps in all directions).
My system : Typhon64 / CT 8.5 / LinuxMint 22.
ctrlsdemo works properly under Typhon64 / CT 8.4 / Win7Pro.
crtlsdemo works properly under Typhon64 / CT 8.5 / Win7Pro.
Thanks for your help.
tmallet.tm
CT LAB ver 8.50 1 year 11 months ago #18699
pl_ORCA has some problems on Linux
It's an old LAB open task...
Please, give us time to try fix these problems.
PS: Welcome to our Forums.
The following user(s) said Thank You: tmallet.tm
CT LAB ver 8.50 1 year 11 months ago #18702
  • tmallet.tm
Hello Sir
Thanks for your quick reply
Thanks for your work
tmallet.tm
Last edit: by tmallet.tm.
CT LAB ver 8.50 1 year 11 months ago #18703
