CT LAB ver 5.50 11 years 3 months ago #7781
---- LAB CT version 5.50 Tasks list ----
-Task10 Add MultiArch support on Debian 8.x Linux
-Task11 Add MultiArch support on Ubuntu 15.04 (Ubuntu, Ubuntu-Mate, Kubuntu etc)
-Task12 Add MultiArch support on Sabayon Linux (Manjaro Based)
-Task14 Add MultiArch support on LinuxMint 17.2
-Task20 Add MultiArch support on Manjaro Linux (ArchLinux Based)
-Task50 Fix DirectX 12 API samples
2015-08-08 Revision: 005415 LAB Actions.
--17-07-2015 Update pl_PowerPDF to ver 5.5.1
--18-07-2015 ADD Support for Debian 8.x (MultiArch for GTK2, QT4 and QT5)
--20-07-2015 ADD Support for Ubuntu 15.04 (MultiArch for GTK2, QT4 and QT5)
--24-07-2015 Update pl_FPSpreadsheet to ver 5.5.1
--24-07-2015 Update pl_Shapes to ver 5.5.1
--29-07-2015 ADD Support for Windows 10 (MultiArch)
--30-07-2015 Update pl_ECControls to ver 5.5.1 (Internal ver 0.9.2.12)
--04-08-2015 Update pl_Graphics32 to ver 5.5.1 SVN Rev 2204
--04-08-2015 Update pl_ZeosDBO to ver 7.2.0.21 SVN Rev 3638
--04-08-2015 Update pl_BGRAbitmap to ver 8.7.2 SVN Rev 1118
--04-08-2015 Update pl_Indy to ver 10.6.2.12 SVN Rev 5295
--04-08-2015 Update pl_WST to ver 5.5.1 SVN Rev 4248
--04-08-2015 Update pl_LuiControls to ver 5.5.1 SVN Rev 1385
--04-08-2015 Update pl_Win_Directx12 to ver 5.5.1 GIT hash: a10680b8f88735f6289300f73a0e066e20637793
--05-07-2015 ADD Support for LinuxMint 17.2 (MultiArch for GTK2, QT4 and QT5)
--05-08-2015 Update pl_RX to ver 5.5.1 SVN Rev 4255
--05-08-2015 Update pl_DWScript to ver 5.5.1 GIT hash: 5f7d2ecaba91dd74c87ed0455ac280ef1b657fbb
--06-08-2015 Fix Direct X 12 (Windows 10) samples, for Win32 only
--07-08-2015 Update FPC to SVN Rev 31301
--08-08-2015 Synchronize with Lazarus SVN Rev 49612
2015-08-28 Revision: 005420 LAB Actions.
--08-08-2015 Update BinUtils to ver 2.25.1 (21-07-2015)
--10-08-2015 Update pl_PasDoc to ver 5.5.1 SVN Rev 1382
--10-08-2015 Update pl_BGRAControls to ver 5.5.1 SVN Rev 103
--10-08-2015 Update pl_GLScene to ver 5.5.1 SVN Rev 6675
--10-08-2015 Update pl_Win_Directx12 to ver 5.5.2 GIT hash: 5306ec05b54ba602969ee774dbf69427beb90c4d
--10-08-2015 Update p7zip to ver 9.38.1 (03-01-2015)
--11-08-2015 ADD pl_TSMBIOS ver 5.5.1 to Typhon IDE Components System
--11-08-2015 Update lz_FpVectorial to ver 5.5.1
--11-08-2015 Update lz_OpenGL to ver 5.5.1
--11-08-2015 Update lz_LeakView to ver 5.5.1
--11-08-2015 Update pl_OpenGL to ver 5.5.1
--12-08-2015 Update lz_PackageManager to ver 5.5.1
--12-08-2015 Update lz_Report to ver 5.5.1
--12-08-2015 Update lz_ReportDialogControls to ver 5.5.1
--12-08-2015 Update lz_ReportOfficeImport to ver 5.5.1
--12-08-2015 Update pl_KControls to ver 5.5.1 (Internal ver 1.7)
--12-08-2015 ADD pl_OpenWeather ver 5.5.1 to Typhon IDE Components System
--13-08-2015 Update ctPobuilder to ver 5.5
--13-08-2015 Update mingw32 for Win32 to Version 4.9.3 build 05-8-2015
--13-08-2015 Update mingw64 for Win64 to Version 4.9.3 build 05-8-2015
--15-08-2015 Update CrossBuild Scripts
--19-08-2015 ADD pl_ExCompress ver 5.5.1 to Typhon IDE Components System
--19-08-2015 ADD pl_ExGeographic ver 5.5.1 to Typhon IDE Components System
--20-08-2015 ADD lz_ReportSpreadsheetExport ver 5.5.1 to Typhon IDE Components System
--20-08-2015 Update pl_WST to ver 5.5.2 SVN Rev 4275
--20-08-2015 Update pl_FPSpreadsheet to ver 5.5.1 SVN Rev 4275
--21-08-2015 Update pl_FontEngine to ver 5.5.1
--27-08-2015 Update FPC to SVN Rev 31429
--27-08-2015 Synchronize with Lazarus SVN Rev 49718
2015-09-08 Revision: 005431 (RC1) LAB Actions.
--30-08-2015 Update pl_CeosMW to ver 5.5.2 GIT hash: 191e0822b9fbc3522decb65a85f8bcc764929ea3
--30-08-2015 Update pl_DWScript to ver 5.5.2 GIT hash: 6fe182745e77feafc04ebb2650b238be2595242a
--31-08-2015 Update lz_Report to ver 5.5.2
--31-08-2015 Update lz_ReportEmailExport to ver 5.5.1
--31-08-2015 Update lz_ReportSpreadSheetExport to ver 5.5.2
--01-09-2015 FIX "PATH" problems on MS Windows OS
--02-09-2015 Update pl_PasDoc to ver 5.5.2 SVN Rev 1389
--02-09-2015 Update pl_ZeosDBO to ver 7.2.0.22 SVN trunk Rev 3641
--02-09-2015 Update pl_Indy to ver 10.6.2.14 SVN Rev 5301
--02-09-2015 Update pl_GLScene to ver 5.5.2 Synchronize with SVN Rev 6676
--02-09-2015 Update pl_LuiControls to ver 5.5.2 SVN Rev 1391
--02-09-2015 Update pl_FPSpreadsheet to ver 5.5.2 SVN Rev 4309
--02-09-2015 Update pl_PascalSCADA to ver 5.5.1 SVN Rev 932
--04-09-2015 Update fpgui_toolkit to ver 1.4.1 GIT hash: bbb778bb08116c7dae543c3af441143ce77f5aec
--04-09-2015 Update ds_fpGUI_IDE to ver 5.5.1
--04-09-2015 Update pl_RichView to ver 5.5.1
--07-09-2015 ADD Multi-Desktop Support for GlassDocking (BETA)
--08-09-2015 Update FPC to SVN Rev 31577
--07-09-2015 Synchronize with Lazarus SVN Rev 49771
Note2: Please post to this topic any suggestion or problem or fix for LAB CT ver 5.50
The following user(s) said Thank You: swallow95
CT LAB ver 5.50 11 years 3 months ago #7782
  • DiMiTRiOS
  • DiMiTRiOS's Avatar
1). Pascal bindings for GDAL library
2). Import Type Library wizard ..
AI can not win the natural stupidity
CT LAB ver 5.50 11 years 3 months ago #7783
we will try
CT LAB ver 5.50 11 years 3 months ago #7784
  • zeljko
  • zeljko's Avatar
  • Thank you received: 38
add
LRS Explorer
sourceforge.net/projects/lrsexplorer/files/
work linux
CT LAB ver 5.50 11 years 3 months ago #7785
my suggestion is to use ctresbuilder
it's lrs and res file builder and work on ALL OSes
CT LAB ver 5.50 11 years 3 months ago #7786
  • zeljko
  • zeljko's Avatar
how to find ctresbuilder
add CodeTyphon Tools
CT LAB ver 5.50 11 years 3 months ago #7787
ctresbuilder locate at
codetyphon/typhon/bin32 or bin64
You can open ctresbuilder from Typhon IDE
or from CodeTyphon Center
Just make a lrs or res (file new)
-drag and drop files to ctresbuilder
-save..
CT LAB ver 5.50 11 years 3 months ago #7790
  • zeljko
  • zeljko's Avatar
Thanks sternas,
How can I add ctresbuilder to Typhon 32 IDE, SmallIDE
debian 32
CT LAB ver 5.50 11 years 3 months ago #7791
just open and build
/usr/codetyphon/typhon/tools/ctresbuilder/ctresbuilder.lpi
move ctresbuilder executable to
/usr/codetyphon/typhon/bin32
The following user(s) said Thank You: zeljko
CT LAB ver 5.50 11 years 3 months ago #7806
  • XANDR
  • XANDR's Avatar
Add full integrated android apk builder and deployer into CT (like Delphi)
CT LAB ver 5.50 11 years 3 months ago #7818
  • atlandev.ct
  • atlandev.ct's Avatar
Can you add some sort of "autocorrect" in the IDE and authorize his edition.
like wihle (auto correct) become while
like thne (auto correct) become then
etc...
Same behavior found in a word processor.
You can add a grid in option menu with 2 entries
1- word to change
2- changing word(s)
CT LAB ver 5.50 11 years 3 months ago #7819
  • Vbxler
  • Vbxler's Avatar
Do not worry if you make a spelling mistake, the compiler will show you the exact line. ;)
CT LAB ver 5.50 11 years 3 months ago #7863
  • Bernd Klingesberger
  • Bernd Klingesberger's Avatar
For the wish to use the GDAL-lib. I believe that this bindings can only use with the versions of GDAL less than 1.9.
File Name: GDALUTM2La...in32.zip
File Size:768 KB
CT LAB ver 5.50 11 years 3 months ago #7869
We release LAB CodeTyphon (CT) 5.5 Revision 005415
more info at first page.
One of many, CT now can build DirectX 12 applications on Windows 10.
Please test and report or suggest....
CT LAB ver 5.50 11 years 3 months ago #7875
  • Vbxler
  • Vbxler's Avatar
I just compiled CT5.5 with Win32 and use it with Win64 and it works.
If I select 'MessageBox' and F1 press, then I get the chm viewer. That's so fine.
But when I select 'Copyfile' and press F1, I get the Code-Browser and not the Helpfile.
Is this a deliberate behavior?
Last edit: by Vbxler.
CT LAB ver 5.50 11 years 3 months ago #7878
Yes Sir
we must finish/update *.chm files
CT LAB ver 5.50 11 years 2 months ago #7914
  • TheWolf
  • TheWolf's Avatar
I found an very interesting libary sadly its for Delphi only, but it is an very powerful threading libary
github.com/gabr42/OmniThreadLibrary
CT LAB ver 5.50 11 years 2 months ago #7915
it's only for windows
CT LAB ver 5.50 11 years 2 months ago #7934
  • Leslie
  • Leslie's Avatar
  • Thank you received: 4
Someone already mentioned that Synopse mORMot ( GitHub ) coud be a great addtion to CT. It is really extensive and well maintained.
Last edit: by Leslie.
CT LAB ver 5.50 11 years 2 months ago #7935
mORMot need a lot of work,
it's Delphi Code for Windows target only
