CT LAB ver 5.50 11 years 2 months ago #8098
  • Alexandr
  • Alexandr's Avatar
Greetings great lazarus developers :)
I suggest add this cool controls to the CodeTyphon as pallete components.
TATTabs - github.com/Alexey-T/ATTabs
TATGroups - github.com/Alexey-T/ATGroups
It looks cool, also they are OS-independent.
But they don't supports designer (dont know why).
Can you add them to CT? :)
CT LAB ver 5.50 11 years 2 months ago #8099
your suggestion it's in our To-Do List
CT LAB ver 5.50 11 years 2 months ago #8115
  • user01
  • user01's Avatar
renaming packages wasn't really a great idea. only brought compatibility and googling problems. now if here anything i need to search about some component i don't even know the package name.
CT LAB ver 5.50 11 years 2 months ago #8116
  • user01
  • user01's Avatar
Printers has been fixed half a year ago. 5.50 has some over a year old version.
svn.freepascal.org/svn/lazarus/trunk/components/printers/
github.com/alrieckert/lazarus/tree/master/components/printers
Last edit: by user01.
CT LAB ver 5.50 11 years 2 months ago #8119
we will check and fix this
CT LAB ver 5.50 11 years 2 months ago #8123
  • user01
  • user01's Avatar
particularly ifdefs. os based, not widgetset based. so gtk2 can be compiled for windows as well.
CT LAB ver 5.50 11 years 2 months ago #8153
  • user01
  • user01's Avatar
and not sure how to make, but if possible, tool windows to show always above main window. it's tool windows like spk content editor, actionlist editor, imagelist editor. etc. so they won't hide behind main window when you need to change properties.
CT LAB ver 5.50 11 years 1 month ago #8193
  • user01
  • user01's Avatar
and got a source code broken. double coded utf8. recoded utf8 files with utf8 again.
Could not load SSL library 11 years 1 month ago #8211
  • usbdoo
  • usbdoo's Avatar
CT LAB ver 5.50
debian-8.2.0-amd64-DVD-1.iso
unit Unit1;
{$mode objfpc}{$H+}
interface
uses
  Classes, SysUtils, FileUtil, IdHTTP, IdSSLOpenSSL, Forms, Controls, Graphics,
  Dialogs, StdCtrls;
type
  { TForm1 }
  TForm1 = class(TForm)
    Button1: TButton;
    IdHTTP1: TIdHTTP;
    IdSSLIOHandlerSocketOpenSSL1: TIdSSLIOHandlerSocketOpenSSL;
    mInput: TMemo;
    moutput: TMemo;
    procedure Button1Click(Sender: TObject);
  private
    { private declarations }
  public
    { public declarations }
  Form1: TForm1;
implementation
{$R *.lfm}
{ TForm1 }
  request:TIdHTTPRequest;
  response:TIdHTTPResponse;
  streamInput:TMemoryStream;
  streamOutput:TStream;
  requestQuery:String;
   try
    streamOutput := TMemoryStream.Create;
    streamInput := TMemoryStream.Create;
    IdSSLIOHandlerSocketOpenSSL1.SSLOptions.CertFile := '/home/usb/test-tls.cer';
    IdSSLIOHandlerSocketOpenSSL1.SSLOptions.Method := TIdSSLVersion.sslvTLSv1_2;
    IdHTTP1.IOHandler := IdSSLIOHandlerSocketOpenSSL1;
    request := TIdHTTPRequest.Create(IdHTTP1);
    requestQuery:='<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:fu="http://www.fu.gov.si/" xmlns:xd="http://www.w3.org/2000/09/xmldsig#">'+
                  '<soapenv:Body>'+
                  '<fu:EchoRequest>test echo</fu:EchoRequest>'+
                  '</soapenv:Body>'+
                  '</soapenv:Envelope>';
    mInput.Lines.Add(requestQuery);
    minput.Lines.SaveToStream(streamInput);
    streamInput.Position := 0;
    request.Source := streamInput;
    request.Method := 'POST';
    request.Accept := 'text/xml';
    request.Connection := 'KeepAlive';
    request.ContentType := 'text/xml; charset=utf-8';  // 'application/soap+xml'
    request.CustomHeaders.Add('SOAPAction: /echo');
    IdHTTP1.Post('https://blagajne-test.fu.gov.si:9002/v1/cash_registers', streamInput);
    response := IdHTTP1.Response;
    streamOutput := response.ContentStream;
    streamOutput.Position := 0;
    moutput.Lines.LoadFromStream(streamOutput);
  finally
    streamInput.Free;
    streamOutput.Free;
end.
usb@debian:~$ apt-cache policy openssl libssl-dev
openssl:
  Installed: 1.0.1k-3+deb8u1
  Candidate: 1.0.1k-3+deb8u1
  Version table:
 *** 1.0.1k-3+deb8u1 0
        500 cdrom://[Debian GNU/Linux 8.2.0 _Jessie_ - Official amd64 DVD Binary-1 20150906-11:13]/ jessie/main amd64 Packages
        500 http://ftp.si.debian.org/debian/ jessie/main amd64 Packages
        500 http://security.debian.org/ jessie/updates/main amd64 Packages
        100 /var/lib/dpkg/status
libssl-dev:
  Version table:
usb@debian:~$
Could not load SSL library.
Please help.
For me it is very important to find a solution to this problem?
Last edit: by usbdoo.
Broken LFM files 11 years 1 month ago #8216
  • user01
  • user01's Avatar
Happened again. Got LFM files broken. Seems like it happens when opening the project. If the project remains active it won't happen next time you open CT. But if you switch to other project, then reopen your projects back LFM files gets broken, double recoded into UTF8.
