CT LAB ver 5.00 12 years 2 months ago #5647
15-Jul-2014 Revision: 004935 LAB Actions
--15-7-2014 Update to FPC SVN Rev 28224
--15-7-2014 Synchronize with Lazarus SVN Rev 45873
--15-7-2014 MEGA-Build to All Host OSes-OK (must test FreeBSD32 again i386-freebsd.7z for make error:209)
--15-7-2014 Fix doceditor Building
01-Aug-2014 Revision: 004941 LAB Actions
--16-7-2014 Update pl_KControls to Ver 1.5.0 and CodeOcean Samples
--16-7-2014 Synchronize with Lazarus SVN Rev 45890
--17-7-2014 Update pl_BGRAbitmap to SVN Rev 774
--17-7-2014 Update pl_Castle to SVN Rev 13926
--17-7-2014 Update pl_ZeosDBO to SVN Rev 3227
--19-7-2014 Synchronize with Lazarus SVN Rev 45932
--19-7-2014 Update FPC to SVN Rev 28239
--20-7-2014 ADD to CTCenter settings, ability to NOT build tools
--20-7-2014 Update CTCenter Find dialog
--20-7-2014 ADD to Typhon IDE, CHM Builder Exernal Tool (ctchmbuilder)
--20-7-2014 ADD to Typhon IDE, Po Builder Exernal Tool (ctpobuilder)
--20-7-2014 ADD to Typhon IDE, Image Editor Exernal Tool (ctimageeditor)
--20-7-2014 ADD to Typhon IDE, UniEditor Exernal Tool (ctunieditor)
--20-7-2014 Update pl_ExtentIDE to Ver 1.5.2 (add new Exernal Tools)
--20-7-2014 Update FPC to SVN Rev 28245
--21-7-2014 Synchronize with Lazarus SVN Rev 45950
--22-7-2014 Update pl_ExControls to Ver 3.0.8 (add TplColorPalette component)
--26-7-2014 Update FPC to SVN Rev 28267
--26-7-2014 Synchronize with Lazarus SVN Rev 45985
--26-7-2014 Add, Update and Test ZenGL CodeOcean Samples
--29-7-2014 Update FPC to SVN Rev 28272
--30-7-2014 Fix Typhon IDE help system problem (FPC rollback Rev 27762 simpleipc.pp)
--31-7-2014 Fix Typhon IDE localization problems (with new Po Builder tool)
--31-7-2014 MEGA-Build to All Host OSes- ALL OK
13-Aug-2014 Revision 004950 LAB Actions
--03-8-2014 Update pl_ExControls to Ver 3.1.0.1
--03-8-2014 Update pl_ExDesign to Ver 3.1.0.1
--03-8-2014 Update pl_ColorLib to Ver 3.1.0.1
--05-8-2014 Update pl_ExSystem to Ver 3.1.0.1
--05-8-2014 Update pl_SynapseVS to Ver 1.6.0
--07-8-2014 Update pl_KControls to Ver 1.6.0 and CodeOcean Samples
--07-8-2014 Update FPC to SVN Rev 28331
--09-8-2014 Update pl_Castle to SVN Rev 13968
--09-8-2014 Update pl_ZeosDBO to SVN Rev 3227
--09-8-2014 Update pl_WST to SVN Rev 3461
--09-8-2014 Update pl_RX to SVN Rev 3461
--09-8-2014 Update pl_FPSpreadsheet to SVN Rev 3461
--09-8-2014 Update pl_RichView to SVN Rev 3461
--09-8-2014 ADD pl_RichMemo SVN Rev 3461
--11-8-2014 Update pl_ACS to Ver 3.3.1
--11-8-2014 Update pl_OnGuard to Ver 5.1.1
--11-8-2014 ADD pl_DataPort SVN Rev 9
--11-8-2014 Update pl_ECControls to Ver 0.0.1.9
--11-8-2014 Rename pl_Freefpider pkg to pl_FreeSpide
--11-8-2014 Update FPC SVN Rev 28381
--12-8-2014 Synchronize with Lazarus SVN Rev 46038
--13-8-2014 MEGA-Build to All Host OSes- ALL OK
21-Aug-2014 Revision: 004961 LAB Actions
--13-8-2014 Start Typhon IDE "Embedded Form Designer" Task
--14-8-2014 Update pl_GlassDocking to Ver 2.3.6
--14-8-2014 ADD to IDE Options->Desktop selection "Use Docking System"
--15-8-2014 ADD to IDE Options->Desktop selection "Use Embedded Form Designer"
--15-8-2014 ADD to GlassDocking options "Set Default" button
--16-8-2014 FIX lHelp executable start problem
--19-8-2014 Update FPC to SVN Rev 28469
--19-8-2014 Synchronize with Lazarus SVN Rev 46055
--19-8-2014 FIX WinCE Compilation
--21-8-2014 We finish Typhon IDE "Embedded Form Designer" lab Tests and Fixes.
30-Aug-2014 Revision: 004970 LAB Actions
--22-8-2014 FIX some "Embedded Form Designer" problems
--25-8-2014 Add basic support for MacOS 10.9.x
--27-8-2014 Update FPC to SVN Rev 28524
--27-8-2014 Synchronize with Lazarus SVN Rev 46078
--29-8-2014 MEGA-Build to All Host OSes- ALL OK
Note1: You can download and test this version from "CTCenter->Update Manager" and select CT Development Version
Note2: Please post to this topic any suggestion or problem or fix for LAB CT ver 5.00
CT LAB ver 5.00 12 years 2 months ago #5666
  • zeljko
  • zeljko's Avatar
  • Thank you received: 38
debian 7 64 bit
problem download CT 5.0
Start Action at 14-7-14 12:28:49
 [INFO]: CodeTyphon Update Engine settings
1
http://www.pilotlogic.com/codetyphon/development/zzctdirver.ctv
x86_64-linux
zzctdirver.ctv
xxxx5
xxxx6
[INFO]: Download file, please wait..
--2014-07-14 12:28:49--  http://www.pilotlogic.com/codetyphon/development/zzctdirver.ctv
Resolving www.pilotlogic.com (www.pilotlogic.com)... 95.211.160.99
Connecting to www.pilotlogic.com (www.pilotlogic.com)|95.211.160.99|:80... connected.
HTTP request sent, awaiting response... 404 Not Found
2014-07-14 12:28:49 ERROR 404: Not Found.
Terminate Action at 14-7-14 12:28:49
Total time: 00:00:00.232
ExitCode : 0
CT LAB ver 5.00 12 years 2 months ago #5667
Uploading finish, try again
CT LAB ver 5.00 12 years 2 months ago #5676
  • zeljko
  • zeljko's Avatar
Windows XP 32
update version 5
Remove and Build ALL
problems: make.exe
Last edit: by zeljko.
CT LAB ver 5.00 12 years 2 months ago #5707
we fix and this at revision 004935
CT LAB ver 5.00 12 years 1 month ago #5717
  • Steven
  • Steven's Avatar
Help doesn't work in this version too. :(
CT LAB ver 5.00 12 years 1 month ago #5718
1) Go to codetyphon/allzips and delete zzctdirver.ctv file
2) try to update again
CT LAB ver 5.00 12 years 1 month ago #5719
  • Steven
  • Steven's Avatar
Wich error this solution resolve?
CT LAB ver 5.00 12 years 1 month ago #5720
With this action CTCenter will download ALL files from server
with zzctdirver.ctv file the CTCenter check server file version first
zzctdirver.ctv it's a simple text file...codetyphon/allzips files version index file...
CT LAB ver 5.00 12 years 1 month ago #5755
01-8-2014 We release Lab CT rev 004941 Development Version
many fixes and many new tools
Please, test and report here...
CT LAB ver 5.00 12 years 1 month ago #5757
  • Javier
  • Javier's Avatar
Windows 8.1 x64
CTCenter->CrossBuild->FreePascal 32bits->FPC32 Build cross element arm-android (and others) ...
(extract last lines from commandbox)
C:/codetyphon/fpc/bin/i386-win32/rm.exe -f c:/codetyphon/fpcsrc/ide/units/i386-win32/compunit.ppu
C:/codetyphon/fpc/bin/i386-win32/rm.exe -rf units
C:/codetyphon/fpc/bin/i386-win32/rm.exe -f *.o *.ppu *.rst *.s *.a *.dll *.ppl
C:/codetyphon/fpc/bin/i386-win32/rm.exe -rf *.sl
C:/codetyphon/fpc/bin/i386-win32/rm.exe -f fpcmade.* Package.fpc ppas.bat script.res link.res
C:/codetyphon/fpc/bin/i386-win32/rm.exe -f *_ppas.bat
make[2]: Leaving directory `c:/codetyphon/fpcsrc/ide/compiler'
make[1]: Leaving directory `c:/codetyphon/fpcsrc/ide'
C:/codetyphon/fpc/bin/i386-win32/make -C installer distclean
make[1]: Entering directory `c:/codetyphon/fpcsrc/installer'
C:/codetyphon/fpc/bin/i386-win32/rm.exe -f install.exe writeidx.exe install.o writeidx.o libpinstall.a libpwriteidx.a libimpinstall.a libimpwriteidx.a
C:/codetyphon/fpc/bin/i386-win32/rm.exe -f units/i386-win32/scroll.ppu units/i386-win32/insthelp.ppu
make[1]: Leaving directory `c:/codetyphon/fpcsrc/installer'
C:/codetyphon/fpc/bin/i386-win32/rm.exe -f build-stamp.*
C:/codetyphon/fpc/bin/i386-win32/rm.exe -f base.build-stamp.*
No se pudo encontrar C:\codetyphon\fpcsrc\compiler\utils\*.exe
No se pudo encontrar c:\codetyphon\fpcsrc\utils\*.exe
[ERROR]: win32 Cross Element for arm-android NOT Exists
sorry, build STOP
Terminate Action at 02/08/2014 10:34:11
Total time: 00:04:02.986
ExitCode : 0
In CTC 4.9 obtain same error
Win32 to Win64 work well ...
(full output in attach)
CT LAB ver 5.00 12 years 1 month ago #5759
  • Javier
  • Javier's Avatar
some words in UniEdit (dutch, deutsch ... no idea :) )
Font Type instead of Lettertype ... sound better for me
...nothing serious
CT LAB ver 5.00 12 years 1 month ago #5761
Is the first release...
CT LAB ver 5.00 12 years 1 month ago #5763
  • 4aiman's Avatar
Hi!
What about debugger?
Doesn't work properly within CT 4.92 when using pl_glscene. GDB crashes/stops once hits ANY breakpoint.
What about constant "Floating point error"?
Logs are below. There were 2 errors ("Floating point error") and 2 dumps.
Warning: Spoiler!
CT LAB ver 5.00 12 years 1 month ago #5765
  • XANDR
  • XANDR's Avatar
Some error (regression) was found. CT LAB ver 5.00 (rev 004941). Host OS: Win7 64. Target OS: WinCE. Target processor family: arm. Created simple GUI application. Set the option "target processor" to "default" and build app - successful. If set the option "target processor" to any other value (for example "ARMV7") and build app - compile error: unit1.pas(2285,0) Error: Error while assembling exitcode 1. Builded application (with option "default") work fine on my target device, but I think this is important.
CT LAB ver 5.00 12 years 1 month ago #5788
  • Javier
  • Javier's Avatar
LazPaint updated to 6.1 and Turbobird 1.2 ... nice tools :woohoo:
CT LAB ver 5.00 12 years 1 month ago #5789
  • 4aiman's Avatar
4aiman wrote: Hi!
Warning: Spoiler!
Re-posting, since I found the source of "Invalid floating point operation"
Once Assembler window is closed CT stops to throw this error.
Note: Even the default project behaves like this for me.
Oh, I've updated to beta CT 5.0 and the error above has gone nowhere.
Currently my OS is Xubuntu 14.04 (latest updates)
Oh, also libraries status tab is trying to find some libs in all-wrong places or of an all-wrong version.
While I can understand the absence of some QT libs, I just can't get why some other libs are missing after the "Install system libraries" option has been selected:
Currently my libgtkglext is of version 1.2, not 1.0:
So, why not search for some basic name and make symlinks if CT needs other versions and there's NO required version of any particular lib but there IS a higher version?
Or maybe it's worth trying to add some repos to OS to ensure there's the needed version of any lib CT, well, needs?
Anyway, please, pay attention to the "Invalid utf-8 string" error too.
Building CT I still can see messages about ANSI<->UTF-8 wrong conversion.
CT LAB ver 5.00 12 years 1 month ago #5795
13-8-2014 We release Lab CT Revision 004950 Development Version
many fixes and many new componets
The following user(s) said Thank You: Miquel Matas, FredyCC
CT LAB ver 5.00 12 years 1 month ago #5796
We Start Typhon IDE "Embedded Form Designer" task :woohoo:
on Windows (32/64) ALL working OK
but for other Host OSes (Linux, FreeBSD Solaris, etc) we must make a lot of work
screens soon...
CT LAB ver 5.00 12 years 1 month ago #5797
  • avra
  • avra's Avatar
sternas wrote: We Start Typhon IDE "Embedded Form Designer" task :woohoo:
This is incredible news. Can't wait to try it!
Embedded form designer missing and buggy docking are the only things in my wish list at the moment to consider IDE feature complete. Maybe it is good time now to take a look at that old docking bug when tabbed layout is used. To remind you, if any window is tabbed into another one docking works fine until IDE exit, but on IDE restart docking breaks apart completely and we have to restore docking XML config file from backup. The problem is described here:
www.pilotlogic.com/sitejoom/index.php/fo...king-a-second-chance
I will be glad to test any docking fixes if needed.
Thank you once more for hard work!
