CT LAB ver 5.00 12 years 3 weeks ago #5832
  • Alexander
  • Alexander's Avatar
I've got a problem with switching between code window and embedded designer from keyboard.
1. Start an empty project
2. Dock editor/designer window to top window (with component palette)
3. Press F12 twice
First press finely switches to code window, second throws an error message: "Failed to create win32 control, error: 1400 : Invalid window handle."
It belongs to Windows 32 and 64 versions, CT Revision: 004961
WBR, volax
Last edit: by Alexander.
CT LAB ver 5.00 12 years 3 weeks ago #5834
It's time to add support for Mac OS
so tomorrow we will start CT on MacOS 10.9 Lab task
The following user(s) said Thank You: Adriano Soares, kenlee
CT LAB ver 5.00 12 years 3 weeks ago #5839
  • Adriano Soares
  • Adriano Soares's Avatar
Great news!
CT LAB ver 5.00 12 years 3 weeks ago #5840
  • kenlee
  • kenlee's Avatar
  • Thank you received: 4
:woohoo:
Mac OS !!!!! Really Great News!
CT LAB ver 5.00 12 years 3 weeks ago #5841
Thanks Guys
Until now on MacOS 10.9.x :
-CT installation: OK
-CT Install System Libraries (with Homebrew): OK
-Build Freepascal 32bits : OK
-Build Typhon32 Small IDE: OK
-Build Freepascal 64bits : NO
-Build Typhon64 Small IDE: NO
-etc
soon our screens
CT LAB ver 5.00 12 years 2 weeks ago #5849
  • 4aiman's Avatar
I'm glad you're concerned about BDS-like view... but what about pl_glscene?
GlSceneViewer glitches since CT 2.3 and I've failed to get any answer about glitches I found...
Are those a subject to be fixed?
CT LAB ver 5.00 12 years 2 weeks ago #5850
We will Check / fix and this Sir
but we want help and time for that...
CT LAB ver 5.00 12 years 2 weeks ago #5851
  • Gyula Kampfner
  • Gyula Kampfner's Avatar
I've got another Access Violation error, please check the video below.
link
CT LAB ver 5.00 12 years 2 weeks ago #5852
we will check and this,
PS: professional error report :woohoo:
CT LAB ver 5.00 12 years 2 weeks ago #5854
  • Gyula Kampfner
Thanks :) My english is poor, and becuse of that much simplier for me to record a video than describe the problem :(
CT LAB ver 5.00 12 years 2 weeks ago #5856
Sir your way is much more better... :)
communication is the subject ..
CT LAB ver 5.00 12 years 2 weeks ago #5862
30-8-2014 We release Lab CT Revision 004970 Development Version
This is CT version 5.0 BETA 1 release
Please, test and report here...
CT LAB ver 5.00 12 years 2 weeks ago #5863
  • Miquel Matas
  • Miquel Matas's Avatar
  • Thank you received: 10
CT5 win32 . designer doesn't reflect changes in Object Inspector.
For example, form caption.
Cheers,
CT LAB ver 5.00 12 years 2 weeks ago #5864
CT LAB ver 5.00 12 years 2 weeks ago #5865
  • Gyula Kampfner
jeff wrote: I've got another Access Violation error, please check the video below.
link
Still wrong in the new version.
CT LAB ver 5.00 12 years 2 weeks ago #5866
  • Miquel Matas
Exiting CT 5.0 win32 (on Win 7-x64) I get this Window Error.
See attached file
Last edit: by Miquel Matas.
CT LAB ver 5.00 12 years 2 weeks ago #5868
  • Gyula Kampfner
I don't know this is a bug or not, or simply the new IDE hasn't been finished yet, but I think when I close a project and reopen it, the IDE should look the same as before the close. The IDE should save the size and position of the windows, and should restore them, but this is not the case.
video
CT LAB ver 5.00 12 years 2 weeks ago #5871
miquelmatas wrote: CT5 win32 . designer doesn't reflect changes in Object Inspector.
Cheers,
We fix-it
@jeff
pl_GlassDocking need some work...
CT LAB ver 5.00 12 years 2 weeks ago #5872
  • Alexander
"Traditional" video bug report ;)
Pressing F12 twice to switch from design to code and back again causes exception: CodeTyphon 5 - F12 bug
CT LAB ver 5.00 12 years 2 weeks ago #5873
Finally, it's not so simple to make a working "Embedded Form Designer" for all Host OSes ....
Windows CT users know very well this subject, but for Linux, FreeBSD, Solaris etc CT users it's a new experience
I think, we are in a good way
