Error build CodeOcean sample AndroidWizard appcompatnavigationdrawerdemo1 1 year 6 months ago #18978
  • choki
  • choki's Avatar Topic Author
Got this error
Panic: tool stopped with exit code 127. Use context menu to get more information.
and context menu
Project: Executing command before Compile Reason: State file "/tmp/AppCompatNavigationDrawerDemo1/obj/controls/controls.compiled" of Project is missing.  Executable:/tmp/AppCompatNavigationDrawerDemo1/jni/before_build.sh CurrentDirectory:/tmp/AppCompatNavigationDrawerDemo1/jni/ Parameters: Command Line:/tmp/AppCompatNavigationDrawerDemo1/jni/before_build.sh Parsers: Show all output lines ProcessID:12547 ExitCode:127ExitStatus:32512 Error: Exit code 127
But when i create new blank LAMW project, its compiled without any error,
i wanna learn LAMW from codeocean but all sample cannot compiled.
Error build CodeOcean sample AndroidWizard appcompatnavigationdrawerdemo1 1 year 6 months ago #18979
Please read this
If this NOT solve your problem please,
attach here your LAMW.ini
and give us more info
-your OS
-CT version
-etc
Error build CodeOcean sample AndroidWizard appcompatnavigationdrawerdemo1 1 year 6 months ago #18980
  • choki
  1. I can built simple android app (just with button), and chipset ARMv7a+Soft, from new project without problem.
  2. Default sample from codeocean chipset is x86_64, already switch to ARMv7a+Soft
  3. Restart CT, and try to complile sample but error Panic: tool stopped with exit code 127. Use context menu to get more information.
my LAMW.ini
[NewProject]
NDKRelease=26.3.11579264
PathToSmartDesigner=/usr/local/codetyphon/typhon/components/packages_pw/pw_AndroidWizard_IDE/source/android_wizard/smartdesigner
PathToJavaTemplates=/usr/local/codetyphon/typhon/components/packages_pw/pw_AndroidWizard_IDE/source/android_wizard/smartdesigner/java
PathToAntBin=/home/manjaro/.buildozer/android/platform/apache-ant-1.9.4/apache-ant-1.9.4/bin
PathToAndroidNDK=/home/manjaro/cadangan/android-sdk/android-ndk-r26d
NDK=6
PathToJavaJDK=/usr/lib/jvm/java-17-openjdk
PathToAndroidSDK=/home/manjaro/cadangan/android-sdk
PrebuildOSYS=linux-x86_32
PathToGradle=/home/manjaro/.gradle/wrapper/dists/gradle-8.0.2-all/14bt34ptcsg1ikmfn78tdh1keu/gradle-8.0.2/
PathToWorkspace=/home/manjaro/Documents/project/rahmat/codetyphon
InstructionSet=1
PackagePrefaceName=org.lamw
[JDKPaths]
0=/usr/lib/jvm/java-17-openjdk
[SDKPaths]
0=/home/manjaro/cadangan/android-sdk
1=/home/manjaro/.buildozer/android/platform/android-sdk
2=/home/manjaro/cadangan/android-sdk/system-images
3=/home/manjaro/cadangan/android-sdk/platforms/android-34
[GradlePaths]
0=/home/manjaro/.gradle/wrapper/dists/gradle-8.0.2-all/14bt34ptcsg1ikmfn78tdh1keu/gradle-8.0.2/
1=/home/manjaro/cadangan/android-sdk/gradle-8.6.1
3=/home/manjaro/cadangan/android-sdk/gradle-8.6.1/bin
4=/home/manjaro/cadangan/android-sdk/gradle-8.6.1/bin
CT version 8.6 QT5
Operating System: Manjaro Linux
KDE Plasma Version: 6.3.4
KDE Frameworks Version: 6.12.0
Qt Version: 6.9.0
Kernel Version: 6.12.21-4-MANJARO (64-bit)
Graphics Platform: X11
Processors: 4 × AMD A12-9720P RADEON R7, 12 COMPUTE CORES 4C+8G
Memory: 11,1 GiB of RAM
Graphics Processor: AMD Radeon R7 Graphics
Manufacturer: ASUSTeK COMPUTER INC.
Product Name: VivoBook_ASUSLaptop X705QA_A705QA
System Version: 1.0
Error build CodeOcean sample AndroidWizard appcompatnavigationdrawerdemo1 1 year 6 months ago #18981
Sir, we never test CT-LAMW on Linux
Attach is our LAB LAMW.ini
In out tests on MS-Windows we use:
-jdk-21
-gradle-8.14
and the latest Android Studio
My suggestion, try to use jdk-21 and gradle-8.14
Error build CodeOcean sample AndroidWizard appcompatnavigationdrawerdemo1 1 year 6 months ago #18982
  • choki
OK never mind Sir,
I will copy and paste CO sample to new project..i think its best way to learn sample..
