wrong php client for Memcached 2 years 3 months ago #18552
  • Boedy Irhadtanto
  • Boedy Irhadtanto's Avatar Topic Author
Dear Admin,
If I am not mistaken the php client for memcached is php_memcached.dll
But in UWS installer there is only one library in extension folder  which is php_memcache.dll (without d)
I think that's is another library.
The php_memcached.dll can be found in here.
pecl.php.net/package/memcached/3.2.0/windows
Regards,
Boedy Irhadtanto
wrong php client for Memcached 2 years 3 months ago #18553
We use
github.com/nono303/memcached
and
github.com/nono303/PHP-memcache-dll
Please, your suggestions
The following user(s) said Thank You: Boedy Irhadtanto
wrong php client for Memcached 1 year 4 months ago #19066
  • Boedy Irhadtanto
I am using php_memcached.dll  from
pecl.php.net/package/memcached/3.3.0/windows
and put it into \php83\extensions\
But I must first copy file libhashkit.dll and libmemcached.dll into C:\Windows\System32\
wrong php client for Memcached 2 months 2 weeks ago #19657
  • Boedy Irhadtanto
I assume you are using memcached server is to serve key-value (just like Redis)
so the client should be php_memcached.dll (not php_memcache.dll without d)
the correct file is pecl.php.net/package/memcached/3.4.0/windows
what I did is to put php_memcached.dll in /extensions folder.
and put libhashkit.dll and libmemcached.dll to folder where php.exe located. ( I used to put it in windows/system32/  but It is better to put it in Ultrawebserver  Folder)
wrong php client for Memcached 2 months 2 weeks ago #19658
  • Thank you received: 236
Please give us time to test and report.
