Perhaps it is fix for Nginx unstable after about 50 request per second 2 years 7 months ago #18394
  • Boedy Irhadtanto
  • Boedy Irhadtanto's Avatar Topic Author
Dear PilotLogic,
I made load test in Nginx Ultrawebserver using Locust. And I found that UWS with Nginx will crash and  need to be restarted after the test  reach 50-60 request per second.
It seems, it is because we need to set the environment before running php-cgi.exe.
I make bat file to set environment. and Nginx become more stable.
The bat file only consist of 2 lines.
set PHP_FCGI_MAX_REQUESTS=1024
set PHP_FCGI_CHILDREN=3,
btw I run manually with
php-cgi.exe -b 127.0.0.1:9123
I am not sure, If I could put it somewhere as default configuration.
Regards,
Boedy
Last edit: by Boedy Irhadtanto. Reason: add more detailed explanation
Perhaps it is fix for Nginx unstable after about 50 request per second 2 years 7 months ago #18395
  • Thank you received: 236
We will test and report.
The following user(s) said Thank You: Boedy Irhadtanto
