Nginx Create Virtual Host and PHP/FPM 4 years 5 months ago #17060
  • Boedy Irhadtanto
  • Boedy Irhadtanto's Avatar Topic Author
Dear Admin,
I am glad there is Vhost configuration panel to simplify process of creating Apache  Vhost.
But Recently I need to explore Nginx. Is there any plan to create similar panel for Nginx.
This Nginx is kind new to me. I also try to find php-fpm switch to enable/disable in UWS,
Boedy
Nginx Create Virtual Host and PHP/FPM 4 years 5 months ago #17061
  • Thank you received: 236
Yes
we want to make Vhost configuration panel  and for Nginx but we need time for that.
Enable/Disable php-fpm switch don't exists for Nginx now.
You can use Nginx "custom configuration file", UWS ability
and to write your Nginx configuration without php-fpm
The following user(s) said Thank You: Boedy Irhadtanto
