Ultra Web Server 3.7 bugs 5 years 6 months ago #15774
  • Neophitus
  • Neophitus's Avatar Topic Author
- Nginx: change root folders don't work. Folders never really change.
- I cannot define Nginx as a primary webserver (and delete Apache if I wanted).
- Some unused elements can be successfully erased, but others leave unwanted remains and an element generates a crash (FileZilla).
- MySQL versions after 8.0.18 don't work: "Failed to find valid data directory. Data Dictionary initialization failed. Aborting"
- The option "Start-up pages/Display page1 at start-up" cannot be disabled via GUI, just by editing the configuration file.
- Typo: Elements "Mamager" -> Manager
- Typo: Stop ALL "suppored" servers -> supported
- PHP 8.0.3 (don't work):
    * Configuration files (.ini) refer to the "php_gd2.dll" extension, but the correct name for this version is "php_gd.dll".
    * Option "track_errors" no longer exists. Must be removed from ini files. Fatal error.
    * Missing extensions: "php_pdo_firebird.dll", "php_xmlrpc.dll". Not included, but enabled by default. Error.
The following user(s) said Thank You: Sternas Stefanos, Matis A.
Last edit: by Neophitus. Reason: New bugs on PHP 8.0.3 element
Ultra Web Server 3.7 bugs 5 years 6 months ago #15775
  • Thank you received: 236
please give us time to fix all these
80%
This working OK to LAB UWS version.
    * Missing extensions:  "php_xmlrpc.dll". Not included, but enabled by default. Error.
The following user(s) said Thank You: Neophitus
Ultra Web Server 3.7 bugs 5 years 6 months ago #15778
And
<<- I cannot define Nginx as a primary webserver (and delete Apache if I wanted).>>
Apache is the primary web server, we can't change this.
<<- Nginx: change root folders don't work. Folders never really change.>>
We are working on this
Thanks again for your report,
please, please, test and UWS 3.8
Ultra Web Server 3.7 bugs 5 years 6 months ago #15779
Sir (@Neophitus)
it was a Great Report  !!!
Thanks from all LAB programmers.
Ultra Web Server 3.7 bugs 5 years 6 months ago #15780
  • Neophitus
Steps to reproduce the problem: deselect the option. Close the program (GUI). Open it again. The option remains checked when returning.
Ultra Web Server 3.7 bugs 5 years 6 months ago #15781
  • Neophitus
You are welcome. But...
I should like to thank the team for the effort in corrections. Thanks!!!
Ultra Web Server 3.7 bugs 5 years 6 months ago #15782
We will continue tomorrow, with your bug list.
Ultra Web Server 3.7 bugs 5 years 6 months ago #15793
  • Neophitus
Should I create a bug topic for version 3.8 or should I wait for version 3.9?
Ultra Web Server 3.7 bugs 5 years 6 months ago #15794
Please, create a new bug topic
