Media upload only small images 5 years 10 months ago #15398
  • Theo Kamphuis
  • Theo Kamphuis's Avatar Topic Author
I use the server with Wordpress and I have problems uploading media. I can only upload very small images. I tried to change the PHP settings, but all settings seemed ok to me.
PHP version 7.4
The error is The server is too bussy or the file are too big.
Please help me out.
Media upload only small images 5 years 10 months ago #15399
  • Thank you received: 236
Did you select for PHP the modified PHP ini ?
Did you restart the Servers after changes to PHP ini ?
Try to set and post_max_size
Media upload only small images 5 years 10 months ago #15400
  • Theo Kamphuis
I will try. When I use nginx I have no problem.
Media upload only small images 5 years 10 months ago #15401
  • Theo Kamphuis
I tried post_max_size 120M, but still the message:
Image post-processing failed because the server was busy or does not have enough resources. Uploading a smaller image can help. Recommended maximum size is 2500 pixels.
Media upload only small images 5 years 10 months ago #15404
I don't know Sir
please search on the web for:
"Wordpress media size"
I think It's not UWS problem
Media upload only small images 5 years 10 months ago #15416
  • Theo Kamphuis
I did some checks and when I install WordPress and change permalinks in WordPress to filename I get an access error..
That is becouse in ultra webserver in apache http.conf file the 'Options Indexes FollowSymLinks' is comented out. The default setting in other webservers (xampp) is:
'Options Indexes FollowSymLinks Includes ExecCGI'
When I change it in the http.conf in ultra webserver all works.
Media upload only small images 5 years 10 months ago #15418
we will test and fix-it in UWS
