Pascal Framework for Ultra Web Server 6 years 9 months ago #14363
  • PizzaProgram (László Szakmári)
  • PizzaProgram (László Szakmári)'s Avatar Topic Author
  • Delphi7 programmer since 25 years
Thank you very much for creating UWS! :)
I would like to create a complex pizza-order interface for my clients (restaurants) that works in synchron with my APP.
Can somebody recommend a modern, easy to use, professional framework, that can be used with pascal?
(Instead of PHP, Java, Ruby, ...) Like AngularJS or similar.
Or should I forget about it, if I would like to implement modules like " Barion Creditcard payment plugin " or "Google Map" services and should start learning Java ?
All I've found (after 5 hours of search) are either 5-20000$ licence plugins, or noname, abandoned, 1-person developed Github repos... :-(
- What do you guys use / recommend?
- What is mostly tested using UWS?
Thanks for any recommendation!
Pascal Framework for Ultra Web Server 6 years 9 months ago #14364
We build UWS and for this reason.
We test CodeTyphon pas2js library with UWS
but need work.
Yes, this market place need a pascal way...
