Components and Libraries for Scripting Development, discussions, problems and suggestions
Titan Script Unit Importer ver 1.02 bugs 11 years 4 months ago #7661
  • zeljko
  • Thank you received: 38
debian 8 32
CodeTyphon 5.4
FPTiffCmn.pas
not compile Const:
33. TiffRational0: TTiffRational = (Numerator: 0; Denominator: 0);
34. TiffRational72: TTiffRational = (Numerator: 72; Denominator: 1);
math.pas
360. operator ** (bas, exp0 : float) e: float; inline;
361. operator ** (bas, exp0 : int64) e: int64; inline;
ComCtrls.pp
2483
- property Align read GetAlign write SetAlign default alTop;
+ property Align: TAlign read GetAlign write SetAlign default alTop;
Last edit: by zeljko.
Titan Script Unit Importer ver 1.02 bugs 11 years 4 months ago #7662
Titan Script Unit Importer can't import all LCL units ...
it's a Script... not compiler.
My suggestion is to remove not Imported functions or class properties from Generated units
PS: Titan Script it's a high level technology library,
the main problem is in Base_tScripter_Call.inc assembly code
and we want help on this...
Titan Script Unit Importer ver 1.02 bugs 11 years 4 months ago #7663
  • zeljko
Thanks sternas
I think that's wrong ComCtrls.pp
2483
I not can do TStringList not work Add(
Titan Script Unit Importer ver 1.02 bugs 11 years 4 months ago #7664
Sir, you can put your code to Generated units and make TStringList.Add
function to work
Unit Importer it's just a help tool and a good start, to make your Script API for you App
like JAVA API
We have plans for Titan Script but, now we have other priorities...like:
-IDE improves and fixes
-More basic libraries (like pl_OpenALS )
-etc
Titan Script Unit Importer ver 1.02 bugs 11 years 4 months ago #7665
  • zeljko
Thanks sternas,
I tried.
unit Classesh_imp;
{$mode objfpc}{$H+}
interface
uses
  Classes, SysUtils,
  base_engine, titanscripter;
procedure RegisterTotalFor_Classesh;
implementation
var H, G:Integer;
    GoR,GoW: TTitanMethodDefinition;
function TStrings_GetLBS:TTextLineBreakStyle;
 begin result:= TStrings(_Self).TextLineBreakStyle; end;
procedure TStrings_SetLBS(Value: TTextLineBreakStyle);
 begin  TStrings(_Self).TextLineBreakStyle:= Value; end;
function TStrings_GetDelimiter: Char;
 begin result:= TStrings(_Self).Delimiter; end;
procedure TStrings_SetDelimiter(Value: Char);
 begin  TStrings(_Self).Delimiter:= Value; end;
function TStrings_GetDelimitedText: String;
 begin result:= TStrings(_Self).DelimitedText; end;
procedure TStrings_SetDelimitedText(Value: String);
 begin  TStrings(_Self).DelimitedText:= Value; end;
function TStrings_GetLineBreak: String;
 begin result:= TStrings(_Self).LineBreak; end;
procedure TStrings_SetLineBreak(Value: String);
 begin  TStrings(_Self).LineBreak:= Value; end;
function TStrings_GetStrictDelimiter: Boolean;
 begin result:= TStrings(_Self).StrictDelimiter; end;
procedure TStrings_SetStrictDelimiter(Value: Boolean);
 begin  TStrings(_Self).StrictDelimiter:= Value; end;
function TStrings_GetQuoteChar: Char;
 begin result:= TStrings(_Self).QuoteChar; end;
procedure TStrings_SetQuoteChar(Value: Char);
 begin  TStrings(_Self).QuoteChar:= Value; end;
function TStrings_GetNameValueSeparator: Char;
 begin result:= TStrings(_Self).NameValueSeparator; end;
procedure TStrings_SetNameValueSeparator(Value: Char);
 begin  TStrings(_Self).NameValueSeparator:= Value; end;
function TStrings_GetValueFromIndex(Index: Integer): String;
 begin result:= TStrings(_Self).ValueFromIndex[Index]; end;
procedure TStrings_SetValueFromIndex(Value: String; Index: Integer);
 begin  TStrings(_Self).ValueFromIndex[Index]:= Value; end;
function TStrings_GetCapacity: Integer;
 begin result:= TStrings(_Self).Capacity; end;
procedure TStrings_SetCapacity(Value: Integer);
 begin  TStrings(_Self).Capacity:= Value; end;
function TStrings_GetCommaText: String;
 begin result:= TStrings(_Self).CommaText; end;
procedure TStrings_SetCommaText(Value: String);
 begin  TStrings(_Self).CommaText:= Value; end;
function TStrings_GetCount: Integer;
 begin result:= TStrings(_Self).Count; end;
function TStrings_GetNames(Index: Integer): String;
 begin result:= TStrings(_Self).Names[Index]; end;
function TStrings_GetObjects(Index: Integer): TObject;
 begin result:= TStrings(_Self).Objects[Index]; end;
procedure TStrings_SetObjects(Value: TObject; Index: Integer);
 begin  TStrings(_Self).Objects[Index]:= Value; end;
function TStrings_GetValues(const Name: string): String;
 begin result:= TStrings(_Self).Values[Name]; end;
procedure TStrings_SetValues(Value: String; const name: string);
 begin  TStrings(_Self).Values[Name]:= Value; end;
function TStrings_GetStrings(Index: Integer): String;
 begin result:= TStrings(_Self).Strings[Index]; end;
procedure TStrings_SetStrings(Value: String; Index: Integer);
 begin  TStrings(_Self).Strings[Index]:= Value; end;
function TStrings_GetText: String;
 begin result:= TStrings(_Self).Text; end;
procedure TStrings_SetText(Value: String);
 begin  TStrings(_Self).Text:= Value; end;
function TStrings_GetStringsAdapter: IStringsAdapter;
 begin result:= TStrings(_Self).StringsAdapter; end;
procedure TStrings_SetStringsAdapter(Value: IStringsAdapter);
 begin  TStrings(_Self).StringsAdapter:= Value; end;
{TStringsList}
function TStringList_GetDuplicates: TDuplicates;
 begin result:= TStringList(_Self).Duplicates; end;
procedure TStringList_SetDuplicates(Value: TDuplicates);
 begin  TStringList(_Self).Duplicates:= Value; end;
function TStringList_GetSorted: Boolean;
 begin result:= TStringList(_Self).Sorted; end;
procedure TStringList_SetSorted(Value: Boolean);
 begin  TStringList(_Self).Sorted:= Value; end;
function TStringList_GetCaseSensitive: Boolean;
 begin result:= TStringList(_Self).CaseSensitive; end;
procedure TStringList_SetCaseSensitive(Value: Boolean);
 begin  TStringList(_Self).CaseSensitive:= Value; end;
function TStringList_GetOnChange: TNotifyEvent;
 begin result:= TStringList(_Self).OnChange; end;
procedure TStringList_SetOnChange(Value: TNotifyEvent);
 begin  TStringList(_Self).OnChange:= Value; end;
function TStringList_GetOnChanging: TNotifyEvent;
 begin result:= TStringList(_Self).OnChanging; end;
procedure TStringList_SetOnChanging(Value: TNotifyEvent);
 begin  TStringList(_Self).OnChanging:= Value; end;
function TStringList_GetOwnsObjects: Boolean;
 begin result:= TStringList(_Self).OwnsObjects; end;
procedure TStringList_SetOwnsObjects(Value: boolean);
 begin  TStringList(_Self).OwnsObjects:= Value; end;
procedure _RegCIOs0;
Begin
    {TPersistent}
    G:=RegisterClassTypeSX(TPersistent);
    RegisterMethodSX(G,'Destructor Destroy; override;', @TPersistent.Destroy);
    RegisterMethodSX(G,'procedure Assign(Source: TPersistent); virtual;', @TPersistent.Assign);
    RegisterMethodSX(G,'Procedure FPOAttachObserver(AObserver : TObject);', @TPersistent.FPOAttachObserver);
    RegisterMethodSX(G,'Procedure FPODetachObserver(AObserver : TObject);', @TPersistent.FPODetachObserver);
    RegisterMethodSX(G,'Procedure FPONotifyObservers(ASender : TObject; AOperation : TFPObservedOperation; Data : Pointer);', @TPersistent.FPONotifyObservers);
    RegisterMethodSX(G,'function  GetNamePath: string; virtual; {dynamic;}', @TPersistent.GetNamePath);
   {TStrings}
   G:=RegisterClassTypeSX(TStrings);
   RegisterMethodSX(G,'destructor Destroy; override;', @TStrings.Destroy);
   RegisterMethodSX(G,'function Add(const S: string): Integer; virtual; overload;', @TStrings.Add);
   RegisterMethodSX(G,'function AddObject(const S: string; AObject: TObject): Integer; virtual; overload;', @TStrings.AddObject);
   RegisterMethodSX(G,'function Add(const Fmt : string; const Args : Array of const): Integer; overload;', @TStrings.Add);
   RegisterMethodSX(G,'function AddObject(const Fmt: string; Args : Array of const; AObject: TObject): Integer; overload;', @TStrings.AddObject);
   RegisterMethodSX(G,'procedure Append(const S: string);', @TStrings.Append);
   RegisterMethodSX(G,'procedure AddStrings(TheStrings: TStrings); overload; virtual;', @TStrings.AddStrings);
   RegisterMethodSX(G,'procedure AddStrings(const TheStrings: array of string); overload; virtual;', @TStrings.AddStrings);
   RegisterMethodSX(G,'Procedure AddText(Const S : String); virtual;', @TStrings.AddText);
   RegisterMethodSX(G,'procedure Assign(Source: TPersistent); override;', @TStrings.Assign);
   RegisterMethodSX(G,'procedure BeginUpdate;', @TStrings.BeginUpdate);
   RegisterMethodSX(G,'procedure Clear; virtual; abstract;', @TStrings.Clear);
   RegisterMethodSX(G,'procedure Delete(Index: Integer); virtual; abstract;', @TStrings.Delete);
   RegisterMethodSX(G,'procedure EndUpdate;', @TStrings.EndUpdate);
   RegisterMethodSX(G,'function Equals(Obj: TObject): Boolean; override; overload;', @TStrings.Equals);
   RegisterMethodSX(G,'function Equals(TheStrings: TStrings): Boolean; overload;', @TStrings.Equals);
   RegisterMethodSX(G,'procedure Exchange(Index1, Index2: Integer); virtual;', @TStrings.Exchange);
   RegisterMethodSX(G,'function GetEnumerator: TStringsEnumerator;', @TStrings.GetEnumerator);
   RegisterMethodSX(G,'function GetText: PChar; virtual;', @TStrings.GetText);
   RegisterMethodSX(G,'function IndexOf(const S: string): Integer; virtual;', @TStrings.IndexOf);
   RegisterMethodSX(G,'function IndexOfName(const Name: string): Integer; virtual;', @TStrings.IndexOfName);
   RegisterMethodSX(G,'function IndexOfObject(AObject: TObject): Integer; virtual;', @TStrings.IndexOfObject);
   RegisterMethodSX(G,'procedure Insert(Index: Integer; const S: string); virtual; abstract;', @TStrings.Insert);
   RegisterMethodSX(G,'procedure InsertObject(Index: Integer; const S: string; AObject: TObject);', @TStrings.InsertObject);
   RegisterMethodSX(G,'procedure LoadFromFile(const FileName: string); virtual;', @TStrings.LoadFromFile);
   RegisterMethodSX(G,'procedure LoadFromStream(Stream: TStream); virtual;', @TStrings.LoadFromStream);
   RegisterMethodSX(G,'procedure Move(CurIndex, NewIndex: Integer); virtual;', @TStrings.Move);
   RegisterMethodSX(G,'procedure SaveToFile(const FileName: string); virtual;', @TStrings.SaveToFile);
   RegisterMethodSX(G,'procedure SaveToStream(Stream: TStream); virtual;', @TStrings.SaveToStream);
   RegisterMethodSX(G,'procedure SetText(TheText: PChar); virtual;', @TStrings.SetText);
   RegisterMethodSX(G,'procedure GetNameValue(Index : Integer; Out AName,AValue : String);', @TStrings.GetNameValue);
   RegisterMethodSX(G,'function  ExtractName(Const S:String):String;', @TStrings.ExtractName);
    GoR:=RegisterMethodSXF(G,'function _GetLBS: TTextLineBreakStyle;',@TStrings_GetLBS );
    GoW:=RegisterMethodSXF(G,'procedure _SetOnChange(Value: TTextLineBreakStyle);',@TStrings_SetLBS);
   RegisterPropertySX(G,GoR,GoW,'TextLineBreakStyle','TTextLineBreakStyle');
    GoR:=RegisterMethodSXF(G,'function _GetDelimiter:Char;',@TStrings_GetDelimiter );
    GoW:=RegisterMethodSXF(G,'procedure _SetDelimiter(Value: Char);',@TStrings_SetDelimiter);
   RegisterPropertySX(G,GoR,GoW,'Delimiter','Char');
    GoR:=RegisterMethodSXF(G,'function _GetDelimitedText: String;',@TStrings_GetDelimitedText );
    GoW:=RegisterMethodSXF(G,'procedure _SetDelimitedText(Value: String);',@TStrings_SetDelimitedText);
   RegisterPropertySX(G,GoR,GoW,'DelimitedText','String');
    GoR:=RegisterMethodSXF(G,'function _GetLineBreak: String;',@TStrings_GetLineBreak );
    GoW:=RegisterMethodSXF(G,'procedure _SetLineBreak(Value: String);',@TStrings_SetLineBreak);
   RegisterPropertySX(G,GoR,GoW,'LineBreak','String');
    GoR:=RegisterMethodSXF(G,'function _GetStrictDelimiter: Boolean;',@TStrings_GetStrictDelimiter);
    GoW:=RegisterMethodSXF(G,'procedure _SetStrictDelimiter(Value: Boolean);',@TStrings_SetStrictDelimiter);
   RegisterPropertySX(G,GoR,GoW,'StrictDelimiter','Boolean');
     GoR:=RegisterMethodSXF(G,'function _GetQuoteChar: Char;',@TStrings_GetQuoteChar);
     GoW:=RegisterMethodSXF(G,'procedure _SetQuoteChar(Value: char);',@TStrings_SetQuoteChar);
   RegisterPropertySX(G,GoR,GoW,'QuoteChar','Char');
     GoR:=RegisterMethodSXF(G,'function _GetNameValueSeparator: Char;',@TStrings_GetNameValueSeparator);
     GoW:=RegisterMethodSXF(G,'procedure _SetNameValueSeparator(Value: char);',@TStrings_SetNameValueSeparator);
   RegisterPropertySX(G,GoR,GoW,'NameValueSeparator','Char');
     GoR:=RegisterMethodSXF(G,'function _GetValueFromIndex(Index: Integer): String;',@TStrings_GetValueFromIndex);
     GoW:=RegisterMethodSXF(G,'procedure _SetValueFromIndex(Value: char; Index: Integer);',@TStrings_SetValueFromIndex);
   RegisterPropertySX(G,GoR,GoW,'ValueFromIndex[Index: Integer]','String');
     GoR:=RegisterMethodSXF(G,'function _GetCapacity: Integer;',@TStrings_GetCapacity);
     GoW:=RegisterMethodSXF(G,'procedure _SetCapacity(Value: Integer);',@TStrings_SetCapacity);
   RegisterPropertySX(G,GoR,GoW,'Capacity','Integer');
     GoR:=RegisterMethodSXF(G,'function _GetCommaText: String;',@TStrings_GetCommaText);
     GoW:=RegisterMethodSXF(G,'procedure _SetCommaText(Value: String);',@TStrings_SetCommaText);
   RegisterPropertySX(G,GoR,GoW,'CommaText','String');
     GoR:=RegisterMethodSXF(G,'function _GetCount: Integer;',@TStrings_GetCount);
   RegisterPropertySX(G,GoR,GoW,'Count','Integer');
     GoR:=RegisterMethodSXF(G,'function _GetNames(Index: Integer): String;',@TStrings_GetNames);
   RegisterPropertySX(G,GoR,GoW,'Names[Index: Integer]','String');
     GoR:=RegisterMethodSXF(G,'function _GetObjects(Index: Integer): TObject;',@TStrings_GetObjects);
     GoW:=RegisterMethodSXF(G,'procedure _SetObjects(Value: TObject; Index: Integer);',@TStrings_SetCommaText);
   RegisterPropertySX(G,GoR,GoW,'Objects[Index: Integer]','TObject');
     GoR:=RegisterMethodSXF(G,'function _GetValues(Index: Integer; const Name: String): String;',@TStrings_GetValues);
     GoW:=RegisterMethodSXF(G,'procedure _SetValues(Value: String; const Name: String);',@TStrings_SetValues);
   RegisterPropertySX(G,GoR,GoW,'Values[const Name: string]','String');
     GoR:=RegisterMethodSXF(G,'function _GetStrings(Index: Integer; aIndex: Integer): string;',@TStrings_GetStrings);
     GoW:=RegisterMethodSXF(G,'procedure _SetStrings(Value: String; Index: Integer);',@TStrings_SetStrings);
   RegisterPropertySX(G,GoR,GoW,'Strings[Index: Integer]','String');
     GoR:=RegisterMethodSXF(G,'function _GetText(Index: Integer): string;',@TStrings_GetText);
     GoW:=RegisterMethodSXF(G,'procedure _SetText(Value: String);',@TStrings_SetText);
   RegisterPropertySX(G,GoR,GoW,'Text','String');
     GoR:=RegisterMethodSXF(G,'function _GetStringsAdapter(Index: Integer): IStringsAdapter;',@TStrings_GetStringsAdapter);
     GoW:=RegisterMethodSXF(G,'procedure _SetStringsAdapter(Value: IStringsAdapter);',@TStrings_SetStringsAdapter);
   RegisterPropertySX(G,GoR,GoW,'StringsAdapter','IStringsAdapter');
   {TStringList}
   G:=RegisterClassTypeSX(TStringList);
   RegisterMethodSX(G,'destructor Destroy; override;', @TStringList.Destroy);
   RegisterMethodSX(G,'function Add(const S: string): Integer; override;', @TStringList.Add);
   RegisterMethodSX(G,'procedure Clear; override;', @TStringList.Clear);
   RegisterMethodSX(G,'procedure Delete(Index: Integer); override;', @TStringList.Delete);
   RegisterMethodSX(G,'procedure Exchange(Index1, Index2: Integer); override;', @TStringList.Exchange);
   RegisterMethodSX(G,'function Find(const S: string; Out Index: Integer): Boolean; virtual;', @TStringList.Find);
   RegisterMethodSX(G,'function IndexOf(const S: string): Integer; override;', @TStringList.IndexOf);
   RegisterMethodSX(G,'procedure Insert(Index: Integer; const S: string); override;', @TStringList.Insert);
   RegisterMethodSX(G,'procedure Sort; virtual;', @TStringList.Sort);
   RegisterMethodSX(G,'procedure CustomSort(CompareFn: TStringListSortCompare); virtual;', @TStringList.CustomSort);
    GoR:=RegisterMethodSXF(G,'function _GetDuplicates: TDuplicates;',@TStringList_GetDuplicates);
    GoW:=RegisterMethodSXF(G,'procedure _SetDuplicates(Value: TDuplicates);',@TStringList_SetDuplicates);
  RegisterPropertySX(G,GoR,GoW,'Duplicates','TDuplicates');
    GoR:=RegisterMethodSXF(G,'function _GetSorted: Boolean;',@TStringList_GetSorted);
    GoW:=RegisterMethodSXF(G,'procedure _SetSorted(Value: Boolean);',@TStringList_SetSorted);
  RegisterPropertySX(G,GoR,GoW,'Sorted','Boolean');
    GoR:=RegisterMethodSXF(G,'function _GetCaseSensitive: Boolean;',@TStringList_GetCaseSensitive);
    GoW:=RegisterMethodSXF(G,'procedure _SetCaseSensitive(Value: Boolean);',@TStringList_SetCaseSensitive);
  RegisterPropertySX(G,GoR,GoW,'CaseSensitive','Boolean');
    GoR:=RegisterMethodSXF(G,'function _GetOnChange: TNotifyEvent;',@TStringList_GetOnChange);
    GoW:=RegisterMethodSXF(G,'procedure _SetOnChange(Value: TNotifyEvent);',@TStringList_SetOnChange);
  RegisterPropertySX(G,GoR,GoW,'OnChange','TNotifyEvent');
    GoR:=RegisterMethodSXF(G,'function _GetOnChanging: TNotifyEvent;',@TStringList_GetOnChanging);
    GoW:=RegisterMethodSXF(G,'procedure _SetOnChanging(Value: TNotifyEvent);',@TStringList_SetOnChanging);
  RegisterPropertySX(G,GoR,GoW,'OnChanging','TNotifyEvent');
    GoR:=RegisterMethodSXF(G,'function _GetOwnsObjects: TNotifyEvent;',@TStringList_GetOwnsObjects);
    GoW:=RegisterMethodSXF(G,'procedure _SetOwnsObjects(Value: TNotifyEvent);',@TStringList_SetOwnsObjects);
  RegisterPropertySX(G,GoR,GoW,'OwnsObjects','boolean');
  H:=-1;
 // _RegConstants0;
 //_RegTypes;
 _RegCIOs0;
 // _RegFuncsProcs0;
 // _RegVariables0;
end.
ERROR: Property "Add" not found
Titan Script Unit Importer ver 1.02 bugs 11 years 4 months ago #7668
  • zeljko
TStringsList work
add unit
Initialization
Titan Script Unit Importer ver 1.02 bugs 11 years 2 months ago #8018
  • Chris
  • Chris's Avatar
  • Thank you received: 4
Hi zeljko
I've tried adding your classesh_imp unit to the SimpleIDE demo, creating a TStringList variable and then trying to use it in a script from within the IDE;
Program test;
  T:TStringList;
  T := TStringList.Create;
  T.Add('1234');
  write(T.Text);
  T.Free;
end.
It compiles ok but throws an error "List Index (-1) out of bounds" (even though T.Count returns 1) - did you manage to get TtitanScript working? I'm considering switching my scripting app from PascalScript to Titanscript but I really need TStringList functionality and I can't get this to work via PascalScript in Lazarus (it works ok in Delphi).
Chris
Titan Script Unit Importer ver 1.02 bugs 11 years 2 months ago #8019
  • zeljko
Send Example TitanScript
TStringList work
File Name: SimpleIDE_...ript.zip
File Size:2,747 KB
Typhon 32 work
Typhon 64 not work
Unit allregsystem;
change // ExtDlgs_imp,
change code to script:
Program test;
T:TStringList;
try
T.Add('1234');
ShowMessage(T.strings[0]);
finally
T.Free;
end.
Titan Script Unit Importer ver 1.02 bugs 11 years 2 months ago #8032
  • Chris
  • Chris's Avatar
Thanks zeljko - that seems to work ok, I'll see if I can port my application over to Titanscript..
Titan Script Unit Importer ver 1.02 bugs 11 years 2 months ago #8033
  • Chris
  • Chris's Avatar
don't suppose anyone has successfully used the Clipboard from within titanscript - it's throwing an exception for me...(I am calling the registration function for the imported Clipbrd unit before anyone asks).
