Components and Libraries for Scripting Development, discussions, problems and suggestions
PScripter Help does not match what's supported ? 16 years 8 months ago #165
  • Jim Granville
  • Jim Granville's Avatar Topic Author
I took a simple Lazarus sine-wave maths pgm, and tried it in PScripter.
It seems the help says Char and Extended are legal, but the PScripter
gags on both of those ?!
A syntax check passes, and when it does try and compile, the LineNumber
given makes no sense - it can be blank space!
Is there a help file that better matches what DOES work, or a fix to the PScripter ?
Given the small footprint, and simple download, I thought PScipter could be a good choice, as these pgms do not really need the full Lazarus.
Of course, if the simple types are not implemented, we may have to shelve the idea. :unsure:
