Components and Libraries for HMI/SCADA applications, discussions, problems and suggestions
Bug found and fixed on ModbusTCP.pas 8 years 1 month ago #12745
  • Marco Pinero
  • Marco Pinero's Avatar Topic Author
Hi all.
I got this bug at modbustcp.pas from pl_PascalScada:
At line 410 Codetyphon has this code:
       // data are ok
        for i:=0 to Len-1 do begin
          if (10+i*20)<Length(pkg.BufferToRead) then
            Values[i]:=(LongInt(pkg.BufferToRead[9+(i*2)]) shl 8) + LongInt(pkg.BufferToRead[10+i*2])
          else
            Values[i]:=0
I solved it doing this:
   // data are ok
          if (10+i*2)<Length(pkg.BufferToRead) then  (*<---- it is not I*20 (it is jumping 20 bytes and that's not correct) it must be I*2) *)
          else
            Values[i]:=0
That's all!!!...
Last edit: by Marco Pinero. Reason: Bad text indentation
Bug found and fixed on ModbusTCP.pas 8 years 1 month ago #12746
  • Fabio Luis Girardi
  • Fabio Luis Girardi's Avatar
  • Thank you received: 13
I already have fixed this in Pascalscada repository, some days ago.
Thanks by your feedback!
Moderators: Curt
