TDataPort status active doesn't work 7 months 2 weeks ago #19483
  • Fernando Sandoval
Hi checked DataPort.Active  always return false or null some body check this correct or i make mistake...status never update...
      DataPort.Close();
      Port:=BDSerProj.FieldByName('SerialPort').AsString  ;
      SBaudRate:=BDSerProj.FieldByName('BaudRate').AsString  ;
      DataBits:=BDSerProj.FieldByName('DataBits').AsString  ;
      StopBits:=BDSerProj.FieldByName('StopBits').AsString ;
      SParity:=BDSerProj.FieldByName('Parity').AsString  ;
      FlowControl:=BDSerProj.FieldByName('FlowControl').AsString  ;
      DpSerial.BaudRate:= StrToInt(SBaudRate);
      DpSerial.Port:= Port;
      DpSerial.DataBits:=StrtoInt(Databits);
      DpSerial.StopBits:=StrtoStopBits(Stopbits);
      SetDataPort(DataPort) ;
      DataPort:=DPSerial;
      DataPort.open();
//      actConnectExecute(sender);
      sleep(100);
      FormMain.Update;
    if( Assigned(DataPort)  ) then begin
//      if( DataPort.Active) then begin always going like false
TDataPort status active doesn't work 7 months 1 week ago #19486
  • Fernando Sandoval
On this process from demo i tested and begin the status work but after close and open the port status is false not active
procedure TFormMain.actConnectExecute(Sender: TObject);
if not Assigned(DataPort) then Exit;
if DataPort.Active then //here working status active when port was open
DataPort.Close();
end
else
if pgcMain.ActivePage = tsSerial then
dpSerial.Port := cbSerialPort.Text;
dpSerial.BaudRate := StrToIntDef(cbSerialBitrate.Text, 9600);
end
else
if pgcMain.ActivePage = tsTCP then
dpTCP.RemoteHost := edTCPHost.Text;
dpTCP.RemotePort := edTCPPort.Text;
end
else
if pgcMain.ActivePage = tsUDP then
dpUDP.RemoteHost := edUDPHost.Text;
dpUDP.RemotePort := edUDPPort.Text;
end
else
if pgcMain.ActivePage = tsHTTP then
dpHTTP.Url := edHTTPHost.Text;
end
else
if pgcMain.ActivePage = tsFile then
dpFile.FileName := edFileName.Text;
actConnect.Caption := 'Connecting..';
DataPort.Open();
if DataPort.Active then begin // here status false when port was open status not update when open port...
DataPort.Push(#27);
// send HTTP request
DataPort.Push(#27);
