Problema with Synapse Serial and ARM Build 10 years 11 months ago #8441
  • German Pablo Gentile
  • German Pablo Gentile's Avatar Topic Author
On this code
function GetSerialPortNames: string;
sr : TSearchRec;
Result := '';
if FindFirst('/dev/ttyS*', $FFFFFFFF, sr) = 0 then
raise this exception
synaser.pas(2408,39) Error: range check error while evaluating constants (4294967295 must be between -2147483648 and 2147483647)
Problema with Synapse Serial and ARM Build 10 years 11 months ago #8442
I just change the ATTRIBUTE to a lower number , i think is safe . Example:
///if FindFirst('/dev/ttyS*', $FFFFFFFF, sr) = 0 then
if FindFirst('/dev/ttyS*', $FFFFFFF, sr) = 0 then
