Indy Library Gzip compression 11 years 11 months ago #6506
  • Dinko
  • Dinko's Avatar Topic Author
  • Thank you received: 5
Hello
I wrote some http server application for windows 64 /32 which use gzip indy compression to compress output.
Problem is that from time to time I get zlib error -5 when I try to compress some string.
In attachment you can find my isolated test case which proves that some string can not be compressed using Indy routines.
I thing this is bug inside Indy Library, and I need confirmation or fix. Any help is appreciated.
The purpose of test is to show that Indy
library can not GZIP compress some string
String is saved in file uncompresable.xml
String is loaded into memory and
I cut peace of files and compresse it
After some time I found on peace which
cannot be compressed and program returns
zlib error -5 which means that buffer is
not good. If you change MemLevel from 9 to
lower values or compression level from 9 to
no lower values you can compress this string
but eventually if you try some other strings
you get the same result (-5).
Indy use zlib1.dll (ver 1.2.8) for 32 bit windows
and zlibwapi.dll (ver 1.2.5) for 64 bit windows
I think that something is wrong with Indy
implementation of compression and the way
how -5 error should be interpreted but I'm
not sure. I tried some other pascal zlib libraries
and everyhing is good.
Used version is Windows CodeTyphon 5.1.0, Fpc = 2.7.1,
pl_Indy Source (24-10-2014 SVN Rev 5201)
I appreciate any help from Indy team or CodeTyphon team or
Lazarus team
dll._zip contain zlib1 for 32 windows and zlibwapi from 64 bit windows.
Rename and uncompress it if you do not have your own version.
Regards, Dinko
Indy Library Gzip compression 11 years 11 months ago #6507
Sir, we will test this
