Bug Fix for TIdFTPServer List Unicode Dir/FileName 12 years 1 week ago #6177
  • 605356316
  • 605356316's Avatar Topic Author
I'm writing an ftp server by using TIdFTPServer.
It shows unicode directory and filename correctly under Windows.
But It doesn't show that under linux.
I had trace indy ftp server codes for several days, such as Setp in debugging, snipper data packets by wireshark.
FINALLY! I found a solution!
In IdFTPServer, procedure TIdFTPServer.DoDataChannelOperation
about line 3686:
      if AContext.FDataChannel.FDataChannel.IOHandler.Connected then begin
        AContext.FDataChannel.FDataChannel.IOHandler.WriteLn(ASrcStrings[i], LEncoding);
change to :
{$IFDEF WINDOWS}
{$ELSE}
        AContext.FDataChannel.FDataChannel.IOHandler.WriteLn(ASrcStrings[i], LEncoding, LEncoding);
{$ENDIF}
It works PERFECTLY!
Bug Fix for TIdFTPServer List Unicode Dir/FileName 12 years 1 week ago #6180
Bug Fix for TIdFTPServer List Unicode Dir/FileName 12 years 3 days ago #6238
  • 605356316
Fix more unicode bugs:
In IdFTPServer, find procedure TIdFTPServer.DoConnect(AContext: TIdContext);
AContext.Connection.IOHandler.DefStringEncoding := IndyTextEncoding_8Bit;
change to:
AContext.Connection.IOHandler.DefStringEncoding := IndyTextEncoding_OSDefault;
In IdCommandHandlers, find procedure TIdCommand.SendReply;
Context.Connection.IOHandler.Write(Reply.FormattedReply);
change to:
{$IFDEF WINDOWS}
  Context.Connection.IOHandler.Write(Reply.FormattedReply, false, IndyTextEncoding_UTF8, IndyTextEncoding_OSDefault);
{$ELSE}
  Context.Connection.IOHandler.Write(Reply.FormattedReply, false, IndyTextEncoding_UTF8, IndyTextEncoding_UTF8);
{$ENDIF}
And there is last bug for change directory while name contains unicode chars, wait for me updating later.
Last edit: by 605356316.
Bug Fix for TIdFTPServer List Unicode Dir/FileName 12 years 3 days ago #6239
  • 605356316
In IdCommandHandlers , find procedure TIdCommandHandler.DoCommand(const AData: string; AContext: TIdContext; AUnparsedParams: string);
    LCommand.FRawLine := AData;
    LCommand.FContext := AContext;
    LCommand.FUnparsedParams := AUnparsedParams;
change to:
{$IFDEF WINDOWS}
    LCommand.FRawLine := UTF8decode(AData);
{$ELSE}
{$ENDIF}
{$IFDEF WINDOWS}
    LCommand.FUnparsedParams := UTF8decode(AUnparsedParams);
{$ELSE}
{$ENDIF}
Now, it solved all of unicode bugs for multiplatform.
I've tested on windows x86 and linux x64
Bug Fix for TIdFTPServer List Unicode Dir/FileName 12 years 3 days ago #6240
please zip and attach all fixed files
Bug Fix for TIdFTPServer List Unicode Dir/FileName 12 years 2 days ago #6243
  • 605356316
Ok, here it is.
Thank you.
Bug Fix for TIdFTPServer List Unicode Dir/FileName 12 years 2 days ago #6244
  • 605356316
Additional, there is part of an example of idftpserver implementation.
procedure FtpServerOnRemoveDirectory(ASender: TIdFTPServerContext;
  var VDirectory: TIdFTPFileName);
  tmpPath: string;
  tmpPath := TrimFilename(BASE_PATH +
    PathDelim + VDirectory + PathDelim);
{$IFDEF WINDOWS}
  tmpPath := UTF8encode(tmpPath);
{$ENDIF}
  if DirectoryExistsUTF8(tmpPath) then
    RemoveDirUTF8(tmpPath);
procedure FtpServerOnListDirectory(ASender: TIdFTPServerContext;
  const APath: TIdFTPFileName; ADirectoryListing: TIdFTPListOutput;
  const ACmd: string; const ASwitches: string);
  Sr: TSearchRec;
  tmpPath: string;
{$IFDEF WINDOWS}
    PathDelim + SysToUTF8(APath) + PathDelim + '*');
{$ELSE}
    PathDelim + APath + PathDelim + '*');
{$ENDIF}
  if FindFirstUTF8(tmpPath, faArchive or faDirectory, Sr) = 0 then
    repeat
      if (Sr.Name <> '.') and (Sr.Name <> '..') then
        with aDirectoryListing.Add do
          if (Sr.Attr and faDirectory) = faDirectory then
            ItemType := ditDirectory;
          end
          else
            ItemType := ditFile;
          FileName := Sr.Name;
          ModifiedDate := FileDateToDateTime(Sr.Time);
          // do your jobs
    until FindNextUTF8(sr) <> 0;
  FindCloseUTF8(sr);
OnChangeDirectory needn't consider converting encoding in implementation, cause there is no interaction with file system.
Other events are similar to OnRemoveDirectory, just convert encoding under Windows.
Bug Fix for TIdFTPServer List Unicode Dir/FileName 12 years 2 days ago #6245
we put these fixes to Lab CT ver 5.20
Bug Fix for TIdFTPServer List Unicode Dir/FileName 12 years 2 days ago #6246
  • 605356316
my ct version is 5.0 :) , maybe there're differences between 5.1 and 5.0 in pl_indy
Bug Fix for TIdFTPServer List Unicode Dir/FileName 12 years 1 day ago #6249
We know that Sir
we add the proper fixed code ...
