Synapse installed but not accesible 14 years 3 months ago #2277
  • Fernando P
  • Fernando P's Avatar Topic Author
Hi to all:
I am trying to use Synapse library, but when I try to compile the project using Synapse units, get next error:
Fatal: Can not find unit blcksock used by unit1. Check if package pl_synapsepkg is in the dependencies.
CodeTyphon Center and Lazarus report Synapse library is installed.
If I copy the Synapse units to proyect directory, compilation is fine.
I'm using CodeTyphon 2.7 without modifications in Ubuntu 12.04 32 bits.
Are there any way to correct this without move the source code into my project's directory?
Thanks in advance.
Saludos desde México
Synapse installed but not accesible 14 years 3 months ago #2279
  • Konstantinos Papadoulas
  • Thank you received: 19
In your project settings enable the use of the Synapse Package.
Here are the Steps:
1) Go to menu "Packages" on the IDE.
2) Select the item "Package Graph"
3) From the new window scroll down until you find the "pl_synapsepkg"
4) Double click on the package name in the Treeview (on the left side)
5) From the new window click on the toolbar button "Use >>"
6) From the popup menu click "Add to project"
7) You are done. Close all windows (if you like :)) and return to the IDE
after this you should be able to compile your application without the need to copy the Synapse *.pas files
in your project directory.
Kostas
Last edit: by Konstantinos Papadoulas. Reason: Corrected some typo's
