Problem compiling project that uses lNetComponents 17 years 7 months ago #17
  • Egroc
  • Egroc's Avatar Topic Author
I'm creating a project that uses TLUDPComponent.
When I try to compile lazarus show error: "identifier not found "__front_type__" (unit lcontainersh.inc)
I cannot find the problem. Any idea?
Thanks a lot!
Re:Problem compiling project that uses lNetComponents 17 years 7 months ago #18
Please send us
1) Which OS (Linux or Windows)
2) Which Lazarus platform (32bit or 64bit)
Don't forget that lNetComponents is not stable yet.
Please help us to "clear" the code....
Attach any source update to this open forum.
Re:Problem compiling project that uses lNetComponents 17 years 7 months ago #19
  • Egroc
Hi!
Sorry: Ubuntu 8.10 32 Bits with Lazarus 32 bits.
Simply create a new project with a form, put a TLUDPComponent in it and compile. Gets error...
I solved problem installing Indy10 and using its UDP components. Indy10 is easy to install (only copy sources and compile/install package). You must consider include it on CodeTyphon.
Thanks for this very usefull tool... I'm very impressive of so easy to install and use.
Greetings, Egroc.
Re:Problem compiling project that uses lNetComponents 17 years 7 months ago #20
We prepare Indy for next release (codeTyphon 0.899)
but first we must solve indy problems with 64bit platforms...
stay connect...
