problem not connec help 5 years 8 months ago #15614
  • Mr Game Bear encrypt
  • Mr Game Bear encrypt's Avatar Topic Author
im try  connect to db en_drop  locahost pass root user root port 3306
pasteboard.co/JQhanU4.png
Last edit: by Mr Game Bear encrypt.
problem not connec help 5 years 8 months ago #15616
  • Thank you received: 233
We want more info
-MariaDB Version of your app ?
-MariaDB Version on your PC ?
-How did you install MariaDB on your PC ?
-Did you "Start" MariaDB Server?
etc
problem not connec help 5 years 8 months ago #15618
i using ultra  webserver download here
mariadb 10.5
pasteboard.co/JQn7tdG.png
problem not connec help 5 years 8 months ago #15621
UWS have only 64Bit libraries (.dll).
You try to build 32bit app and use UWS 64bit libraries (.dll)
this is NOT possible...
32bit app use only 32bit libraries (.dll).
64bit app use only 64bit libraries (.dll).
