Graphics32 TImage32, Jpeg image color problem on Mac OS X Sierra. 9 years 1 month ago #10997
  • Glenn Hudson
  • Glenn Hudson's Avatar Topic Author
I am trying to port a graphics program over from Windows to Mac OS X Sierra using CodeTyphon 6.20 and I am having a problem getting the Graphics32 TImage32 component to display Jpeg images with the correct color. Everything works fine on WIndows but it almost seems like one or more of the color channels are mixed up when I view the exact same image on the Mac. The image displays, but the color is off. The same thing happens when I run the Code Ocean TImage32 example. Has anyone else had this problem?
Thanks in advance for advice.
Kind Regards,
Glenn
Last edit: by Glenn Hudson. Reason: Added addition info
