Searching for PC System - Components 4 years 2 weeks ago #17377
  • Droid c3p0
  • Droid c3p0's Avatar Topic Author
Hi there,
Please inform me about Free PC System - Components like PC Memory info, PC CPU info, and similar ........ if exist anywhere.
Thanks!
MX Linux 23.2;
Typhon version: 8.4
OS: 64 bit MX Linux or 64 bit Windows 11
Last edit: by Droid c3p0.
Searching for PC System - Components 4 years 2 weeks ago #17378
pl_TSMBIOS
and
pl_Win_WMI  (Windows Only)
The following user(s) said Thank You: Droid c3p0
Searching for PC System - Components 4 years 1 week ago #17379
  • Droid c3p0
System:    Kernel: 5.10.0-19-amd64 [5.10.149-2] x86_64 bits: 64 compiler: gcc v: 10.2.1
           parameters: BOOT_IMAGE=/vmlinuz-5.10.0-19-amd64
           root=UUID=<filter> ro quiet splash
           Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm 4.16.1 vt: 7
           dm: LightDM 1.26.0 Distro: MX-21.2.1_x64 Wildflower April 9  2022
           base: Debian GNU/Linux 11 (bullseye)
Machine:   Type: Desktop Mobo: GIGABYTE model: MZBSWMP-00 v: 1.x serial: <filter>
           UEFI-[Legacy]: American Megatrends v: F6 date: 06/13/2018
CPU:       Info: Quad Core model: Intel Celeron J3160 bits: 64 type: MCP arch: Airmont family: 6
           model-id: 4C (76) stepping: 4 microcode: 411 cache: L2: 1024 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 12800
           Speed: 944 MHz min/max: 480/2240 MHz Core speeds (MHz): 1: 520 2: 544 3: 786 4: 922
           Vulnerabilities: Type: itlb_multihit status: Not affected
           Type: l1tf status: Not affected
           Type: mds mitigation: Clear CPU buffers; SMT disabled
           Type: meltdown mitigation: PTI
           Type: mmio_stale_data status: Unknown: No mitigations
           Type: retbleed status: Not affected
           Type: spec_store_bypass status: Not affected
           Type: spectre_v1 mitigation: usercopy/swapgs barriers and __user pointer sanitization
           Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, IBRS_FW, STIBP: disabled,
           RSB filling, PBRSB-eIBRS: Not affected
           Type: srbds status: Not affected
           Type: tsx_async_abort status: Not affected
Graphics:  Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Integrated Graphics
           vendor: Gigabyte driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:22b1
           class-ID: 0300
           Display: x11 server: X.Org 1.20.11 compositor: xfwm4 v: 4.16.1 driver:
           loaded: modesetting unloaded: fbdev,vesa display-ID: :0 screens: 1
           Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.0x22.5")
           s-diag: 1165mm (45.9")
           Monitor-1: HDMI-3 res: 3840x2160 hz: 30 dpi: 52 size: 1872x1053mm (73.7x41.5")
           diag: 2148mm (84.6")
           OpenGL: renderer: Mesa DRI Intel HD Graphics 400 (BSW) v: 4.6 Mesa 20.3.5 compat-v: 3.0
           direct render: Yes
Audio:     Device-1: Intel Atom/Celeron/Pentium Processor x5-E8000/J3xxx/N3xxx Series High
           Definition Audio
           vendor: Gigabyte driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:2284
           class-ID: 0403
           Sound Server-1: ALSA v: k5.10.0-19-amd64 running: yes
           Sound Server-2: PulseAudio v: 14.2 running: yes
Network:   Device-1: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi v: kernel
           modules: wl port: f040 bus-ID: 02:00.0 chip-ID: 8086:24fb class-ID: 0280
           IF: wlan0 state: down mac: <filter>
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Gigabyte
           driver: r8169 v: kernel port: e000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
           IF: eth0 state: up speed: 100 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Intel Wireless-AC 3168 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-5:5
           chip-ID: 8087:0aa7 class-ID: e001
           Report: hciconfig ID: hci0 rfk-id: 1 state: down bt-service: N/A rfk-block:
           hardware: no software: yes address: <filter>
           Info: acl-mtu: 1021:4 sco-mtu: 96:6 link-policy: rswitch sniff link-mode: slave accept
Drives:    Local Storage: total: 704.06 GiB used: 277.18 GiB (39.4%)
           ID-1: /dev/mmcblk0 maj-min: 179:0 model: SD256 size: 238.3 GiB block-size:
           physical: 512 B logical: 512 B type: SSD serial: <filter> scheme: MBR
           SMART Message: Unknown smartctl error. Unable to generate data.
           SMART Message: Unable to run smartctl. Root privileges required.
           ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: BarraCuda 120 SSD ZA500CM10003
           size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD
           serial: <filter> rev: D013 temp: 31 C scheme: MBR
Partition: ID-1: / raw-size: 265.62 GiB size: 260.4 GiB (98.03%) used: 38.58 GiB (14.8%) fs: ext4
           dev: /dev/sda3 maj-min: 8:3
           ID-2: /boot raw-size: 1024 MiB size: 973.4 MiB (95.06%) used: 345.6 MiB (35.5%)
           fs: ext4 dev: /dev/sda2 maj-min: 8:2
Swap:      Kernel: swappiness: 15 (default 60) cache-pressure: 100 (default)
           ID-1: swap-1 type: partition size: 7.73 GiB used: 0 KiB (0.0%) priority: -2
           dev: /dev/sda4 maj-min: 8:4
Sensors:   System Temperatures: cpu: 26.8 C mobo: N/A
           Fan Speeds (RPM): N/A
Repos:     Packages: 2567 note: see --pkg apt: 2560 lib: 1379 flatpak: 7
           No active apt repos in: /etc/apt/sources.list
           Active apt repos in: /etc/apt/sources.list.d/atom.list
           1: deb [arch=amd64] https://packagecloud.io/AtomEditor/atom/any/ any main
           Active apt repos in: /etc/apt/sources.list.d/debian-stable-updates.list
           1: deb http://deb.debian.org/debian bullseye-updates main contrib non-free
           Active apt repos in: /etc/apt/sources.list.d/debian.list
           1: deb http://deb.debian.org/debian bullseye main contrib non-free
           2: deb http://security.debian.org/debian-security bullseye-security main contrib non-free
           Active apt repos in: /etc/apt/sources.list.d/google-chrome.list
           1: deb [arch=amd64] https://dl.google.com/linux/chrome/deb/ stable main
           Active apt repos in: /etc/apt/sources.list.d/librewolf.list
           1: deb [arch=amd64] http://deb.librewolf.net bullseye main
           Active apt repos in: /etc/apt/sources.list.d/megasync.list
           1: deb [signed-by=/usr/share/keyrings/meganz-archive-keyring.gpg] https://mega.nz/linux/repo/Debian_11/ ./
           Active apt repos in: /etc/apt/sources.list.d/microsoft-edge.list
           1: deb [arch=amd64] https://packages.microsoft.com/repos/edge/ stable main
           Active apt repos in: /etc/apt/sources.list.d/mx.list
           1: deb https://mirrors.netix.net/mx/MX-Packages/mx/repo/ bullseye main non-free
           Active apt repos in: /etc/apt/sources.list.d/opera-stable.list
           1: deb https://deb.opera.com/opera-stable/ stable non-free #Opera Browser (final releases)
           Active apt repos in: /etc/apt/sources.list.d/skype-stable.list
           1: deb [arch=amd64] https://repo.skype.com/deb stable main
Info:      Processes: 245 Uptime: 1h 27m wakeups: 1 Memory: 7.62 GiB used: 4.35 GiB (57.0%)
           Init: SysVinit v: 2.96 runlevel: 5 default: 5 tool: systemctl Compilers: gcc: 10.2.1
           alt: 10 Client: shell wrapper v: 5.1.4-release inxi: 3.3.06
Boot Mode: BIOS (legacy, CSM, MBR)
MX Linux 23.2;
Typhon version: 8.4
