[ERROR]: Sorry, Typhon64 Small IDE x86_64-linux-gtk2 NOT Build CT7 5 years 10 months ago #15274
  • Americo Bravo Astroña
  • Americo Bravo Astroña's Avatar Topic Author
Hi, I'm trying to install CT on Ubuntu 20 64bits xfce ram 16gb core i7 7gen ssd disk, first "0) Install System Libraries", then "8) Remove and Build ALL" but I get the following message.
[INFO]: Clean Tools Directory
Build Typhon64 BIG IDE x86_64-linux-gtk2 for Linux
I already tried several combinations but I still have error, thank you for your kind attention.
[ERROR]: Sorry, Typhon64 Small IDE x86_64-linux-gtk2 NOT Build CT7 5 years 10 months ago #15275
Please
-Your CT Version ?
-Your OS ? (Xubuntu 20xx or Ubuntu 20xx with xfce)
-Did you have any other FPC installation ?
-Can you start CTCenter ?
[ERROR]: Sorry, Typhon64 Small IDE x86_64-linux-gtk2 NOT Build CT7 5 years 10 months ago #15277
Hi, thahks for reply.
CT 7.20
cat /etc/issue
Linux Mint 20 Ulyana \n \l
I don't have another fpc.
how to start ct center?
Last edit: by Americo Bravo Astroña.
[ERROR]: Sorry, Typhon64 Small IDE x86_64-linux-gtk2 NOT Build CT7 5 years 10 months ago #15280
  • Vlad Wilhelm
  • Vlad Wilhelm's Avatar
I have similar problems with the old version (6.3).
in ubuntu 20.04 there is no support for gtk 2.0. try switching widget framework to qt5 - it will work. but before running the installer, install the libqt5pas-dev package.
if (as in my case) you need gtk widgets, install the libgtk2.0-dev package. in this case, the codetyphon program will not start, but the studio itself (typhon64) will work.
[ERROR]: Sorry, Typhon64 Small IDE x86_64-linux-gtk2 NOT Build CT7 5 years 10 months ago #15301
Vlad Wilhelm wrote: I have similar problems with the old version (6.3).
Sir CT 6.3 it's very very OLD version
We test (again) LAB CT 7.3 to LinuxMint-xfce linuxmint-20-xfce-64bit.iso
without problem for GTK2
We use this procedure with commands in terminal : 0-0-8
I want to make clear something:
We test before every CodeTyphon Release LAB or NOT
for ALL Host OSes: Windows, Linux, FreeBSD, NetBSD, OpenBSD, DragonFly, Solaris, OpenIndiana and MacOS.
On Linux we tests (before every CodeTyphon Release LAB or NOT) at least: Debian, Ubuntu, Mint, Fedora and Raspberry Pi OS,
for x86, 64_x86, arm32 and arm64
ALL the above tests with the latest OSes Versions.
Some Screens from our tests
PS: Sir @Americo Bravo Astroña
the blue icon in the desktop (like Typhon) is the CTCenter
