Codetyphon running on raspbian problems 11 years 10 months ago #6531
  • German Pablo Gentile
  • German Pablo Gentile's Avatar Topic Author
Short description : don't compile.
Anybody try this? Running Codetyphon side on raspbian? I need it to allow me debug on the same machine it will run.
Best regards.
Codetyphon running on raspbian problems 11 years 10 months ago #6532
CT don't support Raspbian as Host OS yet...
Codetyphon running on raspbian problems 11 years 10 months ago #6533
  • FredyCC
  • FredyCC's Avatar
  • Database/Developer
  • Thank you received: 10
Any distribution of Linux help you to perform debug and get similar results for Raspbian.
Now if it is very necessary I think best suits you Remote Debugging: forum.lazarus.freepascal.org/index.php/topic,20101.15.html, is a better option.
Regards.
The following user(s) said Thank You: German Pablo Gentile
Codetyphon running on raspbian problems 11 years 10 months ago #6534
Agree, that must be better! I don't know it was possible, will try and tell you letter.
Best regards.
Codetyphon running on raspbian problems 11 years 10 months ago #6535
I find the post very confuse. First suggest to check a wiki where the instructions are for ssh debug, and he says using standard debug (not ssh(..
I setup using normal debug, and get a message on raspberry:
Remote debugging from host 192.168125.106 (the op where im running typhoon)
The problem is app never started, just see this message. Im trying a simple form with button before test the real app.
have any idea what can be wrong?
I also include gdb external symbols and dopy full project directory, in any case, to raspberry.
The only thing i can understand on the lazarus forums post is this:
"- Config, make and make install GNU debugger sources to support ARM-Linux system debugging (CrossCompiled ARM debugger)"
I believe is not related to typhoon right?
hope can help me. best regards.
Codetyphon running on raspbian problems 11 years 10 months ago #6536
you must start up gdbserver to the target system
more info here
and here
Codetyphon running on raspbian problems 11 years 10 months ago #6537
Thanks stemas. actually i do. See my comment about the raspberry running on the server:
For some reason debugger never continue.
Checking this sample join the link you send me:
"gdb my_prg
(gdb) target remote 192.168.1.10:2000
Remote debugging using 192.168.1.10:2000
Loaded symbols for /lib64/ld-linux-x86-64.so.2
0x00007ffff7dddaf0 in ?? () from /lib64/ld-linux-x86-64.so.2
(gdb) b main
Breakpoint 1 at 0x400550
(gdb) continue
Continuing.
Breakpoint 1, 0x0000000000400550 in main ()"
I never see this
Loaded symbols for ....
maybe some special check is missing on typhon?
Can send sample project please?
Best regards
Last edit: by German Pablo Gentile. Reason: bad name
Codetyphon running on raspbian problems 11 years 10 months ago #6538
Yes Sir
we are ready to work for this
Codetyphon running on raspbian problems 11 years 10 months ago #6539
To which email please?
if you have a simple project working please let me check for test.
