Key combination problem 11 years 10 months ago #6508
  • Konstantin
  • Konstantin's Avatar Topic Author
Good day!
Problems with keyboard shortcuts.
The combination of Ctrl + C turns into a hard Ctrl + S, Ctrl + V in Ctrl + M, and so on.
Override combination each time - bad decision.
Impossible to work!
How to get rid of this problem?
OS Fedora 20,21
Last edit: by Konstantin.
Key combination problem 11 years 10 months ago #6509
we want more info
your CT version
your CT platform (GTK2 or QT)
etc
Key combination problem 11 years 10 months ago #6510
  • Konstantin
CT 5.0
Platform GTK2
What else is needed?
Key combination problem 11 years 10 months ago #6511
Please Sir
try and CT 5.1, we fix a lot of these problems...
Key combination problem 11 years 10 months ago #6521
  • Konstantin
Which modules implemented tracking pressing?
I would like to experiment with this function introduction.
Key combination problem 11 years 10 months ago #6523
  • Konstantin
Thanks for the answer!
Installing version 5.10 helped.
In fact, it is not clear: help installing a new version or reinstall the environment.
Experiment, now, there is no time.
Capture Shift in combination Ctrl + Shift + <anything> and not made.
It dragged on for several versions of a row CT.
Key combination problem 11 years 10 months ago #6524
my suggestion is update to CT ver 5.1 stable
from CTCenter->Update Manager
is 3 mouse clicks procedure
-click Update from server
-click Download files
-select "Remove and Build All" in new Setup script...
Key combination problem 11 years 10 months ago #6525
  • Konstantin
Update went fine.
Question in recognition pressing the shortcut keys.
With these problems remain for several consecutive issues.
