codetyphon 4.8 toolchain problem on ubuntu 12.04 12 years 6 months ago #5401
  • angman
  • angman's Avatar Topic Author
Hi, I am trying to build the arm-linux-32 tool chain on ubuntu 12.04, but this is wath happens:
Start Action at 15-4-14 09:39:04
GNU Cross toolschains Engine settings
lin32
i386-linux
xxxx
arm
linux
xxxx
arm-linux
xxxx
lin32-arm-linux
BinUtils Build for arm-linux Param:xxxx
sudo: nessun tty presente e nessun programma di richiesta password specificato
Sorry, try again.
Sorry, try again.
Sorry, try again.
sudo: 3 tentativi di immissione password non corretti
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
/usr/lib/codetyphon/ScriptsLin/ln_Cross_Binutils.sh: riga 50: cd: /usr/lib/codetyphon/CrossEng/binutils: File o directory non esistente
/usr/lib/codetyphon/ScriptsLin/ln_Cross_Binutils.sh: riga 56: ./configure: File o directory non esistente
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
[ERROR]: Sorry, Toolschains for arm-linux Param:xxxx NOT Build...
Terminate Action at 15-4-14 09:39:04
Total time: 00:00:00.150
ExitCode : 0
codetyphon 4.8 toolchain problem on ubuntu 12.04 12 years 6 months ago #5402
Did the user has "sudo" root privileges ?
info
codetyphon 4.8 toolchain problem on ubuntu 12.04 12 years 6 months ago #5403
  • angman
Yes, the user has sudo root privileges. The ubuntu is 12.04 64 LTS
codetyphon 4.8 toolchain problem on ubuntu 12.04 12 years 6 months ago #5404
Please Sir
post here (after save and zip) the
CTCenter->HostPC->Get System Info
we need more info.
codetyphon 4.8 toolchain problem on ubuntu 12.04 12 years 6 months ago #5406
  • angman
Ok, here is the system info.
codetyphon 4.8 toolchain problem on ubuntu 12.04 12 years 6 months ago #5408
the only problem is the
CodeTyphon MultiArch mode: 1 must by 0
on Linux MultiArch mode is excremental...
please try
-Set from "CTCenter->Settings" the MultiArch mode: 0
-Reinstall "System Libraries" from CTC.
If this don't work, my suggestion is to reinstall CT
codetyphon 4.8 toolchain problem on ubuntu 12.04 12 years 6 months ago #5409
  • angman
can I set it from CtC center? and if yes, how?
If i need develop applications in a 64 bit pc for arm32 Linux what multiarch Os is better to use?
codetyphon 4.8 toolchain problem on ubuntu 12.04 12 years 6 months ago #5410
1) CTCenter->Settings
2) my opinion Windows 7 -64bit
codetyphon 4.8 toolchain problem on ubuntu 12.04 12 years 6 months ago #5411
  • angman
Tank you. There isn't any othe os that could be good?
codetyphon 4.8 toolchain problem on ubuntu 12.04 12 years 6 months ago #5412
  • angman
Hi, I tried to reinstall all from install.sh, but cannot build the big ide anymore.
Here is the message log:
typhon.pp(245,31) Warning: Constructing a class "TMainIDE" with abstract method "SelComponentPageButtonClick"
/usr/bin/ld: warning: ../link.res contains output sections; did you forget -T?
/usr/bin/ld: cannot find -lGL
typhon.pp(271,1) Error: Error while linking
typhon.pp(271,1) Fatal: There were 1 errors compiling module, stopping
Fatal: Compilation aborted
make[2]: *** [typhon] Errore 1
make[2]: uscita dalla directory "/usr/lib/codetyphon/typhon/ide"
make[1]: *** [bigide] Errore 2
make[1]: uscita dalla directory "/usr/lib/codetyphon/typhon/ide"
make: *** [idebig] Errore 2
codetyphon 4.8 toolchain problem on ubuntu 12.04 12 years 6 months ago #5414
Sir, "cannot find -lGL" your OS don't have OpenGL library
My suggestion is to install again "system libraries"
Why don't use Ubuntu 13.10 ?
codetyphon 4.8 toolchain problem on ubuntu 12.04 12 years 5 months ago #5417
  • angman
Ok, I will try to install system libraries again.
Because it is not LTS support.
codetyphon 4.8 toolchain problem on ubuntu 12.04 12 years 5 months ago #5418
  • angman
Hi sternas. I selected gtk2, then reinstalled the system libraries and the choosed to remove an reinstall all. But the result was the same.
what version of openGL it is necessary? I can try to install it manually.
But i don't understand why if I choose to reinstall all, this doesn't works.
codetyphon 4.8 toolchain problem on ubuntu 12.04 12 years 5 months ago #5419
  • angman
Hi sternas, I have the bigide now. Was a wrong installation of the amd catalyst driver to abort the installation.
codetyphon 4.8 toolchain problem on ubuntu 12.04 12 years 5 months ago #5420
  • angman
Now I am trying to build a toolchan for arm-linux, but this is what I get: (I alredy changed the /etc/sudoeers file adding
angelo ALL = (ALL) NOPASSWD: ALL
Start Action at 19-4-14 16:04:50
lin64
x86_64-linux
xxxx
i386
linux
xxxx
i386-linux
xxxx
lin64-i386-linux
BinUtils Build for i386-linux Param:xxxx
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
Sorry, try again.
[ERROR]: Sorry, Toolschains for i386-linux Param:xxxx NOT Build...
Terminate Action at 19-4-14 16:04:50
Total time: 00:00:00.147
ExitCode : 0
