Problem Ubuntu 10.04 64Bits / Codetyphon 3.10 13 years 9 months ago #2951
  • Marco Pinero
  • Marco Pinero's Avatar Topic Author
I downloaded las version of Codetyphon 3.10 for using it in my Ubuntu 10.04 LTS 64 Bits.
There were no problem with installation following step by step (as I have always done with other versions of Codetyphon).
After a perfect installation I tried to open a project which uses a TIdHTTPServer component (from Indy) and ... surprise!!!.... my IDE raises an error.
Then I realized that when I tryed to put a TIdHTTPServer component into a new Application Project, IDE closes after showing an empty dialog window.
I realized too that other indy components do the same thing to IDE.
I ran using command line "startlazarus64" and got the following messages when I put the component TIdHTTPServer:
AddComponent TIdHTTPServer Parent=Form1:TForm1 95,101,0,0
Parent is 'Form1:TForm1'
TMainIDE.OnPropHookPersistentAdded A IdHTTPServer1:TIdHTTPServer
TPkgManager.AddUnitDependenciesForComponentClasses Adding Project Dependency project1 -> pl_indycomp
TPkgManager.AddUnitDependenciesForComponentClasses Extending Uses unit1.pas IdHTTPServer
[TEventsCodeTool.CompleteComponent] CurComponent=IdHTTPServer1:TIdHTTPServer
TApplication.HandleException Access violation
Stack trace:
$0000000000F442B0
and then IDE closes.
Any idea of what is wrong? :S
Thanx in advance.
Problem Ubuntu 10.04 64Bits / Codetyphon 3.10 13 years 9 months ago #2952
  • FredyCC
  • FredyCC's Avatar
  • Database/Developer
  • Thank you received: 10
Try running Lazarus with root. :dry:
regards
Problem Ubuntu 10.04 64Bits / Codetyphon 3.10 13 years 9 months ago #2965
  • Marco Pinero
I tried, but same problem.
I used ">sudo startlazarus64" and got same result.
Problem Ubuntu 10.04 64Bits / Codetyphon 3.10 13 years 7 months ago #3434
  • Marco Pinero
I've formatted my PC, installed Ubuntu 12.04, installed Codetyphon 4.10, and I got the same problem: when a put a TIdHTTPServer component on form1 on new project:
AddComponent TIdHTTPProxyServer Parent=Form1:TForm1 109,13,0,0
TMainIDE.OnPropHookPersistentAdded A IdHTTPProxyServer1:TIdHTTPProxyServer
TPkgManager.AddUnitDependenciesForComponentClasses Extending Uses unit1.pas IdHTTPProxyServer
[TEventsCodeTool.CompleteComponent] CurComponent=IdHTTPProxyServer1:TIdHTTPProxyServer
Stack trace:
$0000000000F72D80
And close everything.....
:( :angry:
Problem Ubuntu 10.04 64Bits / Codetyphon 3.10 13 years 7 months ago #3466
  • Joao Kho
  • Joao Kho's Avatar
Same here on Ubuntu 12.04 CodeTyphon 4.10 , All Indy Server Protocol has this kind of problems. It's bug on ubuntu version?
Problem Ubuntu 10.04 64Bits / Codetyphon 3.10 13 years 7 months ago #3467
  • Joao Kho
  • Joao Kho's Avatar
After some testing, i found that, if you add Indy Package into your opened Application, and then add IdHttpServer, you can compile and run without problem.
Problem Ubuntu 10.04 64Bits / Codetyphon 3.10 13 years 7 months ago #3468
  • Joao Kho
  • Joao Kho's Avatar
Another testing, after you open package Indy do compile and install, to rebuilt lazarus IDE, you can drop Indy Server Protocols without any problem. May this help.
