Issues with virtual tree view and Kubuntu 64bit 13 years 11 months ago #2529
  • tony
  • tony's Avatar Topic Author
Just installed latest code Typhon on kubuntu 12.04 and
that was no problem at all, but when I add a virtual tree view component
to a form it causes the IDE to crash when I try to remove it from the form,and
if I compile it the application crashes when I close the form.
Anyone have any ideas?
Last edit: by tony.
Issues with virtual tree view and Kubuntu 64bit 13 years 11 months ago #2530
  • tony
Just a fyi, it's the same IDE error I got with Code Typhon 2.7 and Zeos DB components on windows 64bit.
Issues with virtual tree view and Kubuntu 64bit 13 years 11 months ago #2531
  • Adriano Soares
  • Adriano Soares's Avatar
Take a look at
www.pilotlogic.com/sitejoom/index.php/fo...mall-correction#2347
I needed do this correction to work properly with virtual tree view.
The following user(s) said Thank You: tony
Last edit: by Adriano Soares.
Issues with virtual tree view and Kubuntu 64bit 13 years 11 months ago #2532
  • tony
Thanks,
That fixed the issue.
