Installation problem on Ubuntu 8.10 i386 17 years 9 months ago #7
  • TSr
  • TSr's Avatar Topic Author
I can't install CodeTyphon becouse setup.sh script thinks that I have 64 bit system (i have /usr/lib64 directory)! This is not good way to check architecture.
You can use comand:
uname -m
PS
In file: Scripts/ln1_install_SysLibraries_For_Ubuntu.sh is some thing like that:
sudo apt-get update
sudo apt-get install xterm
sudo apt-get install alien
sudo apt-get install libgtk2.0-dev
sudo apt-get install libgdk-pixbuf-dev
sudo apt-get install libgpmg1-dev
Faster way will be:
sudo apt-get update
sudo apt-get install xterm alien libgtk2.0-dev libgdk-pixbuf-dev libgpmg1-dev
EDIT
Executables Like CodeTyphon_ln32.ex has same error. It thinks that I have 64bit system.
In second solution I don't have to confirm every single installation.
Last edit: by TSr.
Re:Installation problem on Ubuntu 8.10 i386 17 years 9 months ago #8
In current Version 0.855, we put all your suggestions and
we change Linux 64 Identification method with "uname -m" system function.
Please try it again...
