Issue with CodeTyphon 8.60 and Sqlite 1 year 8 months ago #18890
  • patrick
  • patrick's Avatar Topic Author
After installing the Sqlite/Sqlite3 packages, the IDE rebuilds correctly but did not start indicating that the Sqlite.dll cannot be found. Therefore, it is not possible to start the IDE to uninstall any packages.
Could you please indicate where the Sqlite dll must be installed to allow CodeTyphon IDE to start normally ? or should I re-install CodeTyphon32 ?
Thanks in advance for any advice
Patrick
Issue with CodeTyphon 8.60 and Sqlite 1 year 8 months ago #18894
For Typhon32
put the libraries in
C:\codetyphon\typhon\bin32\
folder
You can get these libraries from
C:\codetyphon\binRuntimes\i386-win32\
folder
For Typhon64
C:\codetyphon\typhon\bin64\
from
C:\codetyphon\binRuntimes\x86_64-win64\
Issue with CodeTyphon 8.60 and Sqlite 1 year 8 months ago #18895
  • patrick
Thank you so much Matis
This advice is very useful
Have a nice evening
Patrick
