Installation error CodeTyphon Studio Ver 8.10 3 years 2 months ago #17956
  • Javier
  • Javier's Avatar Topic Author
Hi
I am trying to install CodeTyphon Studio Version 8.10 on Windows 11
And I get this error:
Windows could not find the file "binBase\x86_64-win64\pshortcut.exe"
I'll apreciate you help on this issue.
Installation error CodeTyphon Studio Ver 8.10 3 years 2 months ago #17957
  • Thank you received: 233
Your system can NOT find some 7zip files to unzip them
<<El sistema no puede encontrar la ruta especificada>>
<<The system can not find the path specified>>
These files must be in CodeTyphonIns/allzips/ folder
Check your CodeTyphonIns.zip for correct unzip
Installation error CodeTyphon Studio Ver 8.10 3 years 2 months ago #17959
  • Javier
Thanks for your answer
Attached is the content of the zip file.
Installation error CodeTyphon Studio Ver 8.10 3 years 2 months ago #17960
