CT on a ROCK 4 SE - space consumption 3 years 2 months ago #17941
  • Charly
  • Charly's Avatar Topic Author
I got CT8.10 running on a ROCK 4 SE (ARM) under Debian 11; you can even work with it :).
What bothers me, however, is the space requirement. On a 32GB eMMC only 12GB are left free. Is there something like a 'clean' command?
Or, which files that are no longer needed can be deleted and where can I find them?
CT on a ROCK 4 SE - space consumption 3 years 2 months ago #17943
  • Thank you received: 233
CodeTyphon it's a Terra Programming Studio.
We test on Arm32/Arm64 boards with 64G SD or eMMC.
You can delete many NO Arm files
From
allzips/binfpc
allzips/bingcc
allzips/bingdb
allzips/binlldb
allzips/cross
etc
The following user(s) said Thank You: Charly
