CT 8.00 and java? 3 years 6 months ago #17705
  • MAURO VENTURA
  • MAURO VENTURA's Avatar Topic Author
hello guys.
I found big trouble to build the typhoon big ide . i reach the following message :
                 Compile Typhon64 Win64
Makefile:135: *** Compiler C:/Program Files/Java/jdk1.8.0_341/bin.exe not found.  Stop.
[ERROR]: Typhon64 Small-IDE IDE NOT Build
            Build Typhon64 BIG-IDE for Win64
Terminate Action at 19/04/2023 17:56:15
Total time: 00:00:01.250
ExitCode : 0
Is it correct that CT  installer call java compiler ??
Many thanks in advance for any kind of help to  solve my problem.
Mauro
CT 8.00 and java? 3 years 6 months ago #17707
  • Thank you received: 233
hello guys.
NO, NO, CodeTyphon do NOT use Java for installation.
The following user(s) said Thank You: Jeanie, MAURO VENTURA
CT 8.00 and java? 3 years 6 months ago #17709
  • MAURO VENTURA
OK, looking into the batch files dir  CT, it seems there is an wrong  setup in system enviroments variables used for CT.
how can solve my problem?
(I'm very sad because i used for 2 years  typhoon ide with big satisfaction . It s a very professional IDE).
many thanks in advance.
Mauro
CT 8.00 and java? 3 years 6 months ago #17710
Let's try something
-Open CTCenter
-Do CTCenter => CodeTyphon =>"Remove and build ALL"
-Save the log of CT Center action  more info
-Zip or 7zip this log file and post here as attach.
The following user(s) said Thank You: MAURO VENTURA
CT 8.00 and java? 3 years 6 months ago #17720
  • MAURO VENTURA
Hello Matis ,
many thanks for the rescue.
In attachments the logfile as you asked to me.
I tried to change the PP environment variable in C:\codetyphon\fpc\fpc64\bin\x86_64-win64   but without  good results.
if  you need more info please dont' hesitate to ask me.
Mauro
CT 8.00 and java? 3 years 6 months ago #17721
Your PC has installed a make.exe somewhere
this make.exe is the problem
Open a console and type:
Where make.exe
and report here
CT 8.00 and java? 3 years 6 months ago #17723
  • MAURO VENTURA
Hello Matis.
Quickly , the answer was...
C:\WINDOWS\system32>where make.exe
C:\codetyphon\fpc\fpc64\bin\x86_64-win64\make.exe
it seems that PP  env.var.  is the link to the make cmd.
Do you Think it's better to remove it?
Mauro
Last edit: by MAURO VENTURA.
CT 8.00 and java? 3 years 6 months ago #17724
  • MAURO VENTURA
Hello Matis .
Many ,many thanks .
The problem was exactly as you wrote in your last reply.I remove the ENV VAR named PP containinig the link to make.exe . Remove and build everything  . Now it's works fine.
Problem solved !!!
CT 8.00 and java? 3 years 6 months ago #17725
Have fun...
