unit "interfaces" not found 17 years 5 months ago #56
  • Adrian Mesarosiu
  • Adrian Mesarosiu's Avatar Topic Author
I have a problem with CodeTyphon 0.922 beta running on WinXP32/Pro SP2
After the installation went fine, my first try was to run an application (the default blank form).
When compiling i get this fatal error:
"Can't find unit Interfaces used by Project1"
I mention that i haven't mess with the Compiler Options nor with the Project Options. Even after messing with those (and trying to find a fix on the web, even did the stuff found on the Lazarus site) still no luck. Rebuild Lazarus, reset everything to defaults using CodeTyphon Center, blah blah blah... same thing.
I appreciate any help.
TY
Re: unit "interfaces" not found 17 years 5 months ago #57
Please Sir, remove manual all CodeTyphon/lazarus/Freepascal directories
end reinstall/rebuild CodeTyphon (as administrator).
